060-682_ALT_0
SPST Small Rocker Switch w/Green Illumination 12VDC
Brand:| Model: 66-2239
Small illuminated 12 VDC SPST rocker switch. Specifications: • Current rating: 20A @ 12 VDC • Housing dimensions: 28 mm L x 10.5 mm W x 16 mm D • Contacts: 3.
060-682
Weight: 0.01 lbs.
IN STOCK
List Price$4.99
You Save68%
$1.59
Buy 10-99 $1.33
Buy 100-up$1.06
Part # 060-682
  • CircuitSPST
  • Contact Rating @ Voltage20A 12 VDC
  • IlluminationIlluminated
  • BrandParts Express
  • Model66-2239
  • Part Number060-682
  • UPC844632076121
  • Product CategoryRocker Switches
    (2 Reviews)
  • Weight0.01 lbs.
View similar products to the SPST Small Rocker Switch w/Green Illumination 12VDC
in the Rocker Switches product category.
SPST Small Rocker Switch w/Green Illumination 12VDC is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Small rocker illuminated switch (green)The part comes without terminal specs so one needs to figure out which is which. The terminals are numbered 1, 2, 3. I assigned the following terminal 1 to power source, 2 to load, and 3 to common (ground). this worked for me and am using it with DC 12v, 5v, 3.3v, -5v, -12v sources. At 3 & 5 v the illumination dims, at 12v the illumination is bright. It works for me at the levels I am using.
Date published: 2012-09-06
Rated 5 out of 5 by from Great Switch at Great PriceThese Rocker Switches work great at a great price, and can handle most loads (up to 20A at 12V) . The lumination is fine but it is incandescent rather than LED and therefore not as bright as one would expect from an LED, and its color comes from the translucent colored switch. Also FYI, the Large Rocker switches, have only a slightly larger switch than the Small Rockers (1"x1/4" vs 7/8"x1/4") and ironically the large ones have less depth (5/8" vs 3/4").
Date published: 2012-05-16
Looking at Model: 66-2239 switch.
How thick of a panel can it be mounted in
Asked by: cdowdy
The thickest panel you could mount this into securely would be 1/8".
Date published: 2011-03-25
Customer projects that include: SPST Small Rocker Switch w/Green Illumination 12VDC
