091-1144_ALT_0
Spring Loaded Speaker Terminal Pair Nickel 5/8" Tab
Brand:|Part # 091-1144
Intended for speaker driver use, these nickel plated terminal posts are pre-mounted in pairs onto a strong plastic insulator/base.
Part # 091-1144
Intended for speaker driver use, these nickel plated terminal posts are pre-mounted in pairs onto a strong plastic insulator/base. A 1/8" diameter hole in the base facilitates mounting to the loudspeaker chassis via screw or pop rivet. 3/16" holes in the polarity-marked pushbutton binding posts accept up to 8 AWG wire and hold it firmly. 5/8" solder tabs are attached to 7/32" high standoffs, and voice coil tinsel leads may be soldered to the tabs, crimped, or both. An ideal solution for replacing broken loudspeaker driver terminals or for upgrading and customization.
  • Style / TypeDual
  • Contact PlatingNickel
  • BrandParts Express
  • Part Number091-1144
  • UPC844632091643
  • Product CategoryBinding Posts & Plates
  • Unit of MeasurePR
  • Weight0.09 lbs.
View similar products to the Spring Loaded Speaker Terminal Pair Nickel 5/8" Tab
in the Binding Posts & Plates product category.
