091-1142_ALT_0
Spring Loaded Speaker Terminal Pair Nickel 13/16" Tab
These heavy-duty spring loaded terminals are ideal for replacing broken loudspeaker driver terminals or for customization.
091-1142
Weight: 0.073 lbs.
IN STOCK
List Price$5.99
You Save31%
$4.13
Buy 10-up$3.93
Part # 091-1142
Qty:  PR
These heavy-duty spring loaded terminals are ideal for replacing broken loudspeaker driver terminals or for customization. The nickel plated posts are pre-mounted in pairs onto a strong plastic insulator/base. 3/16" holes in the polarity-marked pushbutton binding posts accept up to 8 AWG wire and hold it firmly. 13/16" solder tabs are attached to 1/8" high standoffs, and voice coil tinsel leads may be soldered to the tabs, crimped, or both. A 1/8" diameter hole in the base facilitates mounting to the loudspeaker chassis via screw or pop rivet.
  • Style / TypeDual
  • Contact PlatingNickel
  • BrandParts Express
  • Part Number091-1142
  • UPC844632091636
  • Product CategoryBinding Posts & Plates
  • Unit of MeasurePR
    (3 Reviews)
  • Weight0.073 lbs.
View similar products to the Spring Loaded Speaker Terminal Pair Nickel 13/16" Tab
in the Binding Posts & Plates product category.
Spring Loaded Speaker Terminal Pair Nickel 13/16" Tab is rated 4.6667 out of 5 by 3.
Rated 5 out of 5 by from They work, but with some modificationThese didn't fit the holes on my Altec Lansing 887a "Capri" crossover. They were space wider than the ones they replaced, so I clipped 'em in half, filed them down, and secured them with the locking nut. It was an aggravating process to also bore the small holes in the metal plate on my crossover (I don't have tools, just used a Gerber), but that's to no fault of this part. Once complete, it looked and worked flawlessly.
Date published: 2015-05-20
Rated 4 out of 5 by from Good ProductI used these to replace some plastic spring speaker terminals that had cracked on an old amplifier.Some modification was required (new homemade back plate), but the new terminals worked and should outlast my 32 year old amp.
Date published: 2013-08-14
Rated 5 out of 5 by from Big improvementAdded these to some delta pro 18's , they should come that way from eminence?Used the same screw that they had for the old terminals , works well!
Date published: 2011-11-07
  • 2015-05-27T07:57CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.3
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_091-1142, PRD, sort_mostRecent
For those crimp/solder terminals which are riveted, how does one remove the rivet so as to install the spring loaded terminals? Should it be drilled out---that seems risky.
Asked by: woofernuts
This particular product uses screws which should make disassembly easy. If you find terminals that are riveted and need to remove them, the only way would be to drill them out.
Date published: 2013-12-04
Same question as previous post, what is exact spacing between posts?
I have existing speakers with 5/8" spacing between the holes for connectors so I need to know exact center to center distance.
Asked by: KEF fan
The distance between the posts is 3/4 on center for this connector. I will see if we can have this added to the copy.
Answered by: Chrisf
Date published: 2012-11-26
What is the space in between the posts?
Asked by: Jason J
probably, "dual bananna" plug spacing..about one inch
Answered by: marksteven
Date published: 2012-06-11
  • 2015-05-27T09:04CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.3
  • loc_en_US, sid_091-1142, PRD, sort_recentQuestionsFirst
Customer projects that include: Spring Loaded Speaker Terminal Pair Nickel 13/16" Tab
