091-1152_ALT_0
Spring Loaded Binding Post Speaker Terminal Pair
Speaker Connectors - Just one look at these select connectors and you will see the quality craftsmanship that went into their design. Ruggedly built and gold plated to with stand abuse and oxidation, these connectors are the perfect choice!
  • Gold plated to with stand abuse and oxidation
  • Connectors are the perfect choice for home theatre, home audio, and car stereo
091-1152
Weight: 0.08 lbs.
IN STOCK
List Price$9.99
You Save37%
$6.25
Buy 10-99 $5.80
Buy 100-up$4.80
Part # 091-1152
Speaker Connectors - Just one look at these select connectors and you will see the quality craftsmanship that went into their design. Ruggedly built and gold plated to with stand abuse and oxidation, these connectors are the perfect choice for home theater, home audio, and car stereo. Individually packaged for display and resale.
Specifications: • Overall dimension: 1-1/2" L x 1/2" dia • Threaded stud: 1/2" L x 1/4" • Binding post accepts up to a 10 AWG wire.
  • Style / TypeSingle
  • Contact PlatingGold
  • BrandParts Express
  • Part Number091-1152
  • UPC844632014406
  • Product CategoryBinding Posts & Plates
    (8 Reviews)
  • Weight0.08 lbs.
View similar products to the Spring Loaded Binding Post Speaker Terminal Pair
in the Binding Posts & Plates product category.
Spring Loaded Binding Post Speaker Terminal Pair is rated 4.625 out of 5 by 8.
Rated 5 out of 5 by from Spring Loaded TerminalsI used these to replace the spring clip terminals on a vintage pair of Genesis II+ speakers. Installation was easy and the spring terminal connection hold is large enough to use with Banana plugs or bare wire. Nicely designed.
Date published: 2013-06-13
Rated 3 out of 5 by from Warning: threaded studs are very short!I originally purchased these for the "Overnight Sensation" speaker kit, but I couldn't use them. Unfortunately, the threaded studs are only 1/2" long. My mistake. They can't be used in most cases where they are mounted through a hole drilled in the speaker cabinet. (Unless you're using material that's less than 1/2" thick.)
Date published: 2013-01-08
Rated 5 out of 5 by from Concerned with 22 AWG wireNice connector. Quality finish. I was concerned that this product might cut a 22 AWG stranded wire. I did notice one dent in one of the strands of the wire I tested, but overall, it appears it will work fine with 22 gauge wire. It appears that the force applied when the post is pushed in all the way (to accommodate a 10AWG wire) is much larger than when it is opened enough for a 22 AWG wire. If mounting on metal, my testing shows that a Keystone nylon shoulder washer (PN: 7687) and a nylon flat washer (PN: 3353) should work fine to isolate the connector from the case.
Date published: 2010-02-01
Rated 5 out of 5 by from Very good product.Very good product.
Date published: 2009-06-22
Rated 5 out of 5 by from Just what I neededWill shop here for all my needs
Date published: 2008-09-12
Rated 4 out of 5 by from Short Post LengthThese are great terminals, just be careful if your cabinet is thick, the post may not reach clear through.....
Date published: 2008-03-10
Shaft isolated from mounting hole?
My application is a speaker with a metal plate on the back (KLH 17). Images attached. Does this product have a rubber or plastic insert to isolate the shaft from the mounting hole to prevent shorting across the metal plate? If this one does not, which ones do?
Asked by: rhollingsworth
Unfortunately these are not insulated. For an insulated option please see below.
Date published: 2013-02-05
Customer projects that include: Spring Loaded Binding Post Speaker Terminal Pair
