Speaker Surround Re-Foam Repair Kit For Bose 901/802 Speakers
Brand:|Part # 260-910
This kit will repair the foam surrounds of the 4-1/2" drivers used in the Bose 802 (uses eight drivers) and the famous Bose 901 (uses nine drivers). Save over $400.00 by repairing them yourself!
$39.99
Buy 4+$36.84
Part # 260-910
This refoam kit will repair the foam surrounds of the 4-1/2" drivers used in the Bose 802 (uses eight drivers) and the famous Bose 901 (uses nine drivers). Save over $400.00 by repairing them yourself! Each kit contains supplies to repair up to ten speakers and includes ten foam surrounds, two plastic bottles each filled with 1 oz. of specially formulated adhesive, 12 foam swabs for application of glue, and complete repair instructions.
Specifications: • Foam outside diameter: 4-1/4" • Foam inside diameter: 2-7/8" • Foam outer edge width: 3/16" • Foam inner edge width: 3/16".
Note: This surround repair kit is not intended for use with subwoofers.
  • BrandParts Express
  • Part Number260-910
  • UPC844632043567
  • Product CategorySpeaker Surround Refoam Kits
  • Unit of MeasureKT
    (7 Reviews)
  • Weight0.924 lbs.
View similar products to the Speaker Surround Re-Foam Repair Kit For Bose 901/802 Speakers
in the Speaker Surround Refoam Kits product category.
Speaker Surround Re-Foam Repair Kit For Bose 901/802 Speakers is rated 4.7143 out of 5 by 7.
Rated 5 out of 5 by from Very SurprisedI ordered 1 set thinking that was enough for a pair, but end up ordering another set. I prepared myself by watching the video on Bose 901 speaker repair, but doing the first one was tuff because the glue took so long to cure and doing them out of sequence did not help. The second speaker went together with ease keeping in mind to give the glue time to get tacky before mending the surround to the base and the cone. The speakers sound great and I would recommend this kit.
Date published: 2015-03-12
Rated 5 out of 5 by from Bose 901-speaker repair kitI picked up these Bose speakers off the curb ! Saw the surrounds were rotted , did a little research and found your web site. I consider myself a hands on kinda guy, the key to this kit is the prep work. After cleaning the cabinets in and out and installing the surrounds these speakers ROCK! Thanks guys.
Date published: 2012-10-09
Rated 5 out of 5 by from Wow, Bose told me that I could not fix these. They were wrongAwesome kit. Bose told me that I'd have to send my 901's into there company to get them fixed. Hmmmmmm, I did not beleive them. So I did some research and found your company. Wow am I glad I did. Thanks for the kit's. Thank you, thank you, thank you. My speakers are like new and sound great. I'll be doing more business with you guys.
Date published: 2011-08-26
Rated 4 out of 5 by from OK PRODUCT,NOT EASY TO ASSEM.I BOUGHT TWO OF THESE KITS FOR A PAIR OF 1983 901's I GOT AT A FLEA-MARKET. I THOUGHT THE KIT WAS A BIT PRICY FOR CHEAP FOAM SURR. WITH NO DUST CAPS, BE WORTH IT IF THEY WERE POLY OR RUBBER FOAMS. I USED ONLY ALEEN'S TACKY GLUE & IT MADE IT EASY TO ASSEMBLE. THE GLUE THAT COME WITH KIT TAKES TOO LONG TO DRY & IS MESSY. I HAD TO STRETCH THE FOAMS TO FIT THE CONES PROPERLY, OTHERWISE I WAS SO-SO SATISFIED. P.E. NEEDS TO UPHOLD CUSTOMER SATISFACTION BY SUPPLYING BETTER QUALITY PRODUCTS. STANDARD FOAMS ONLY LAST 15-20 YEARS, POLY OR RUBBER FOAMS LAST 25-50 YEARS.TEXTILE SURR. LAST ALMOST FOREVER. IF P.E. COULD GET BETTER FOAM KITS, CUSTOMERS WOULD BE MORE SATISFIED & SELL MORE KITS.
Date published: 2010-09-28
Rated 5 out of 5 by from Excellent product with easy to follow instructionsThis is an excellent product for restoring your Bose 901's back to original specs and performance. The directions are specifically written for the Bose 4 1/2" HVC Driver. A lot of patience is required though so take your time. I did not remove the speakers from the cabinet so that saved a ton of time. One piece of advice... go to your local craft store and purchase a bottle of "Aleene's Original Tacky Glue". The glue supplied has a very long open time; the Aleene's sets up faster and is easier to work with. This is not an easy project to take on, but with a little patience it s well worth the time spent to enjoy a legendary loudspeaker again for the first time. Good Luck and happy listening.
Date published: 2009-07-14
Rated 5 out of 5 by from great product good priceIt saves me hundreds of dollars on replacement
Date published: 2008-01-17
  • 2016-02-09T06:29CST
  • co_hasreviews, tv_0, tr_7
  • loc_en_US, sid_260-910, PRD, sort_mostRecent
Hi is this kit enough to repair 2 speaker (18) driver Boss 901 . Let me know .thanks
Asked by: Paulngoc
This kit includes 10 surrounds, enough for one speaker. You will need to purchase two kits in order to repair a pair of speakers.
Date published: 2015-07-16
The video informs us of the need to center the voice coil by removing the dust caps & shim the VC. However the picture & contents of this kit doesn't show the shims or caps. Are they included ? If they are not included, how does one center the VC?
Asked by: 007jmp007
The drivers in the bose 901 actually do not have a replaceable dust cap so that part of the video does not apply to this particular speaker
Answered by: Chrisf
Date published: 2015-08-11
How many foam surrounds are include in the kit? Just one or nine?
Asked by: SoundWar
Each kit includes 10 foam surrounds.
Date published: 2014-07-09
  • 2016-02-09T07:01CST
  • loc_en_US, sid_260-910, PRD, sort_recentQuestionsFirst
