Surround Kit For 8" Speaker Foam
Speaker Surround Re-Foam Repair Kit For 8" Speaker
Product Video
Don't throw away expensive loudspeakers just because the foam surround has dry rotted, or has been punctured. With these new refoam kits from Parts Express, you can save BIG bucks by repairing the foam surround and avoid costly loudspeaker replacements.
260-920
Weight: 0.8052 lbs.
IN STOCK
$28.25
Buy 4-up$25.80
Part # 260-920
<p>Don't throw away expensive loudspeakers just because the foam surround has dry rotted, or has been punctured. With these new refoam kits from Parts Express, you can save BIG bucks by repairing the foam surround and avoid costly loudspeaker replacements. The kit includes two pairs of foam surrounds (one pair with a flat inner edge, one pair with an angled inner edge), two pairs of dustcaps (one pair paper, one pair plastic), a plastic syringe filled with 25 cc of adhesive (specially formulated for various speaker cone materials), five foam swabs for application of glue and complete repair instructions. A utility knife and isopropyl alcohol are recommended to remove old foam material, but are NOT included in this kit.</p> <p><strong>Specifications:</strong> • Foam outside diameter: 7-3/4" • Foam inside diameter: 5-1/4" • Foam outer edge width: 1/4" (flat), 3/16" (angled) • Foam inner edge width: 5/16" (flat), 3/8" (angled) • Dustcap diameter: 2-3/4".</p> <p><strong>Note:</strong> This speaker surround repair kit is not designed for use with subwoofers.</p> This kit is confirmed to work on the following Classic Speakers: Advent Prodigy Towers, Acoustic Research AR 18 and 18BX, Boston Acoustics A70, Bose 601, EPI T/E 100, Genesis II 210, Infinity RSE, RSIII, 5001, Kappa 6.1, Mission 762, Realistic Nova-5, Spectralinear 128 and MANY MANY More!!
  • BrandParts Express
  • Part Number260-920
  • UPC844632043536
  • Product CategorySpeaker Surround Refoam Kits
    (63 Reviews)
  • Weight0.8052 lbs.
View similar products to the Speaker Surround Re-Foam Repair Kit For 8" Speaker
in the Speaker Surround Refoam Kits product category.
Speaker Surround Re-Foam Repair Kit For 8" Speaker is rated 4.6508 out of 5 by 63.
Rated 5 out of 5 by from Great product!Worked great. Was simple and easy to do. Just follow the directions and take your time.
Date published: 2014-03-18
Rated 5 out of 5 by from Great product for saving lots of money.Very good product that will work as advertised if you take your time and not rush the job.
Date published: 2014-03-17
Rated 5 out of 5 by from Replaced the foam on my 1982 Avid speakers.Everything went according to plan. The video instructions were great. The pair took a total of 40 minutes to complete. It is so nice to have real full sound again. For years I have been using the all in one book shelf systems and the Bose cd player. They have no soul. I resurrected my College system. It is like I found my soul again. Best $ I've spent in years.
Date published: 2013-11-13
Rated 5 out of 5 by from Easy and simpleMy first time refoaming speakers.Went off without a hitch.Except for not knowing about the ferro fluid inside, everything went according to the instructions.I should have changed the ferro fluid. Thick and sticky.Find out if your old speakers have ferro fluid first!
Date published: 2013-11-11
Rated 5 out of 5 by from Great CompanyItem purchased was as described. Quick ship. Great communication.
Date published: 2013-09-06
Rated 4 out of 5 by from All Purpose Refoam.First and foremost, the surround glue is definitely not Elmer's school glue. The two smell alike, but the dried surround glue has different tactile and strength properties. And even if it was Elmers cow glue, it's still an acceptable adhesive for speaker repair. Some hobbies have way to many ideologues.Everything else works as described; the shims are a nice touch. Both types of foam surround seem durable and I am sure they will do fine for my speakers. I do wonder though if the all purpose dust caps change the specs of the speaker being repaired. They are relatively large for an 8" driver, and I can't help but think they change cone mass or the volume of air pushed, especially if they sit higher on the cone than factory dust caps. Can anyone chime in?Ideally, you'd shim AND save your stock dust caps, but that's in a perfect world. I had to use replacement caps from this kit, which is not the end of the world considering their clean black finish and durable construction.
Date published: 2013-08-15
does the 8" speaker surround foam replacement kit come with voice coil shims?
Asked by: rock
Yes, if dust overs are included the shims are included too.
Answered by: diepert
Date published: 2012-02-17
I have a pair of Jamo CL 25s with rotted foam surrounds. Does anyone know if this kit would be suitable? How does one measure the woofer diameter.?
Asked by: peterb0202
You want to measure the diameter of the cone itself edge to edge. This kit fits a woofer with a cone diameter of 5-3/4" to 6".
Date published: 2013-05-22
Videos
Customer projects that include: Speaker Surround Re-Foam Repair Kit For 8" Speaker
