Surround Kit For 12" Speaker Foam
Speaker Surround Re-Foam Repair Kit For 12" Speaker
Product Video
Don't throw away expensive loudspeakers just because the foam surround has dry rotted, or has been punctured. With these new refoam kits from Parts Express, you can save BIG bucks by repairing the foam surround and avoid costly loudspeaker replacements.
260-930
Weight: 0.8646 lbs.
IN STOCK
$29.90
Buy 4-up$28.58
Part # 260-930
Don't throw away expensive loudspeakers just because the foam surround has dry rotted, or has been punctured. With these new refoam kits from Parts Express, you can save BIG bucks by repairing the foam surround and avoid costly loudspeaker replacements. The kit includes two pairs of foam surrounds (one pair with a flat inner lip, one pair with an angled inner lip), two pairs of dustcaps (one pair paper, one pair plastic), a plastic syringe filled with 25 cc of adhesive (specially formulated for various speaker cone materials), five foam swabs for application of glue and complete repair instructions. A utility knife and isopropyl alcohol are recommended to remove old foam material, but are NOT included in this kit. Specifications: • Foam outside diameter: 11-1/2" • Foam inside diameter: 8-11/16" • Foam outer edge width: 3/8" (flat surround), 1/2" (angled surround) • Foam inner edge width: 5/16" (flat surround), 3/16" (angled surround) • Dustcap diameter: 4".
Note: This speaker surround repair kit is not designed for use with subwoofers.
  • BrandParts Express
  • Part Number260-930
  • UPC844632043482
  • Product CategorySpeaker Surround Refoam Kits
    (45 Reviews)
  • Weight0.8646 lbs.
View similar products to the Speaker Surround Re-Foam Repair Kit For 12" Speaker
in the Speaker Surround Refoam Kits product category.
Speaker Surround Re-Foam Repair Kit For 12" Speaker is rated 4.3778 out of 5 by 45.
Rated 5 out of 5 by from Proper repair kit for older speaker.I was not only pleased by the prompt delivery but also from the man I ordered from. He was very patient about trying to find the right repair kit. He also was very helpful with instructions on how to repair the speaker.
Date published: 2014-07-23
Rated 5 out of 5 by from simplei just repaired a Pyle Driver which had completely lost the surround. with a little patience and minimal skill the job is easy. the hardest part is waiting for the glue to dry between steps (patience).
Date published: 2014-04-27
Rated 3 out of 5 by from Looks like good quality, but too large for my 12"This surround, apparently like all the others sold for 12" drivers, has too large an OD (11.625 versus 11.1875) for my RS Optimus 950 speaker. Before I try to cut it down to use it, should I just cut out a small pie shaped section to shrink the OD or try to cut about 0.22" from the surrounds OD so it fits on the driver's lip without puckering? I've seen the first option and it didn't look nice. The second option seems difficult to do accurately.
Date published: 2014-02-09
Rated 5 out of 5 by from 12" Speaker foam surrond kitThis product was excellent and I didn't have any problem following the instructions. I was looking at over $200.00 to replace the two 12" speakers in my Wurlitzer Omni 5000 Organ. I was able to repair both speakers with this "ONE" kit. The organ is back in working order again. Hope to keep the old girl going for another 30 years! -- "Thanks"
Date published: 2012-12-27
Rated 5 out of 5 by from Can't beat this package!!The surrounds are exactly what it took to refresh my 12" speakers. The kit had very clear instructions and was actually quite simple to do. I have been in electronics for over 40 years, yet my first speaker repair like this. These were my own speakers, so I am being quite picky what type of repair I was making. They may not have been as attractive as factory fresh ones, but the bottom line is they operate just as the original ones. The kit even includes surround for other speakers. You possibly could do a second set with the same kit. A value packed item, even if you can't use the second set!! This package is exactly what you need. Don't be afraid you can't do it, because we all learned how to glue paper together in kindergarten. These are almost that simple.
Date published: 2012-04-05
Rated 4 out of 5 by from Surround Kit For 12" Speaker FoamThese kits can not only save you money, but are easy to replace you old worn out or torn surrounds. The kits are complete with all the materials and you need to replace a pair of damaged surrounds along with easy to follow instructions. Save youself the expence of new speakers and less waste because of damaged or worn surrounds, replace them your self, you win in the end.
Date published: 2011-03-05
Jbl 122a Part no 260974 does your kit come with and outer edge gadget. if not is it necessary to have one. and if so how can I get one?
Asked by:
The inside diameter of the product (260-930 foam kit) is quoted as 8-11/16". Will this product provide too much overlap on the speaker cone if the cone measures 9-1/4 "?
Asked by: Dzim
The inside measurement is from the inside edge of the lip itself. This kit is designed to fit cone diameters from 9-1/8" to 9-1/2" so it will fit yours perfectly.
Date published: 2014-03-06
glue supplied with surround kits
I saw where one user stated he also used Silicone glue to help secure the surrounds to the speaker. Also Several users stating the clue supplied is somewhat watery and or appears to be standard wood glue.My question is, could one use Silicone glue in place of the glue supplied in the kit? This would allow an easier placement and set over having to hold for extended times for the supplied glue to dry.Thank you for taking the time to answer.Brad DeFore
Asked by: Brad1
The glue in the kit is a "hyped-up" version of standard white Elmers glue. This glue works perfectly for foam surrounds and paper cones, however if you are gluing to poly cones we recommend a gel type superglue that is safe on plastics.
Date published: 2013-02-23
I Have a set of MMATS PRO Series 12" subs, 4 ohm car speakers. Do you think this re-foam kit will work with them?
Asked by: Stevienutz
We do not have any kind of cross-reference by brand, model, or anything of the sort for these products. Typically, I would not recommend a foam surround for a subwoofer, but if the dimensions listed for this product match up with your subwoofers, they may do the job.
Answered by: RussR
Date published: 2012-11-29
The drivers I am looking to replace the surround on have a 12mm XMAX, will these surrounds support that much cone movement?
Asked by: defrag010
No, these are designed more for standard-duty home speakers, not high excursion subwoofers or anything of that kind.
Answered by: RussR
Videos
Customer projects that include: Speaker Surround Re-Foam Repair Kit For 12" Speaker
