260-976_ALT_0
Speaker Surround Re-Foam Repair Kit For 12" Cerwin Vega
Product Video
Do you have an old pair of Cerwin Vegas speakers in the basement with rotten surrounds? Repair them with these new surround kits from Parts Express! The surrounds in these refoam kits are exact replacements for each particular size.
260-976
Weight: 0.865 lbs.
IN STOCK
$34.50
Buy 4-up$29.64
Part # 260-976
Qty:  KT
Do you have an old pair of Cerwin Vegas speakers in the basement with rotten surrounds? Repair them with these new surround kits from Parts Express! The surrounds in these refoam kits are exact replacements for each particular size, so your Cerwin Vega driver will perform as it did when it was new from the factory. Each kit contains supplies to repair two speakers and includes red foam surrounds, plastic shims, two Cerwin Vega logo dust caps, 1 oz. of adhesive (specially formulated for various speaker cone materials), five foam swabs for application of glue, and complete repair instructions. A utility knife and isopropyl alcohol are recommended to remove old surround material, but are NOT included in this kit.
Specifications: • Foam outside diameter: 11-1/2" • Foam inside diameter: 8-3/4" • Foam outer edge width: 5/16" • Foam inner edge width: 5/16" • Dustcaps: 3-3/4".
Note: This speaker surround repair kit is not designed for use with subwoofers.
  • BrandParts Express
  • Part Number260-976
  • UPC844632043475
  • Product CategorySpeaker Surround Refoam Kits
  • Unit of MeasureKT
    (18 Reviews)
  • Weight0.865 lbs.
View similar products to the Speaker Surround Re-Foam Repair Kit For 12" Cerwin Vega
in the Speaker Surround Refoam Kits product category.
Speaker Surround Re-Foam Repair Kit For 12" Cerwin Vega is rated 4.2778 out of 5 by 18.
Rated 5 out of 5 by from A perfect fit for my 30-year old Cerwin Vega D7sMy Cerwin Vega D7s were bought in my college days and sounded great then. After many years in storage, my son took them out to use in his room. After a bass test, the gasket around the bass crumbled to dust. One quick search on PE later and we got our replacements and easy installation instructions. It was a perfect fit and the speakers returned to their original sonic glory. Thanks!
Date published: 2014-06-09
Rated 4 out of 5 by from ExcellentMy speakers sound so much better than they did before. The replacement was easy enough for me to follow, however, there was no real explanation on how the cone sits. After a quick repositioning of the way the cone is glued to the foam, and it's beautiful!
Date published: 2014-06-03
Rated 5 out of 5 by from includes everything neededI just repaired my speakers with this kit, they sound and look as good as new.The instructions are easy to follow.
Date published: 2014-02-27
Rated 5 out of 5 by from Just as described, easy and reliable repairI was concerned about sounds quality when the kit arrived. You're never exactly sure what your going to get with aftermarket parts.These speakers have never sounded better! The kit was complete and everything was very high quality.
Date published: 2013-09-28
Rated 5 out of 5 by from Brought new life to old speakersWas recently given a set of Cerwin S-1 speakers. Never got a chance to try them, as the foam had completely rotted off. Did some research, and was ready to send them off to someone and pay a hefty fine. Then I found this site, and more accurately, this kit. First speaker I re-coned, didn't come out so well. The voice coil isn't lined up correctly and makes a scratching sound. My bad, first speaker I've ever re-done. I wasn't a master at it, but its' twin seemed easier and sounds amazing. Will eventually grab this kit again and have another go at the 1st. One is bad enough, 2 oughta be great.
Date published: 2013-05-05
Rated 5 out of 5 by from Works Great!Received these surrounds quickly and they were as advertised. Just follow the directions and take your time. Everything was as advertised...... including the dust covers. They were the correct size.This is a much better solution to rotted surrounds than buying new speakers. And after allowing them to completely dry over night, I installed them in their cabinets, fired up my sound system and they performed great! Sounded like the speakers were brand new.
Date published: 2013-01-23
OK, I think I know what I need however I wanted to make sure. I am going to have to refoam both 12" drivers on a set of Cerwin Vega AT-12s. Do I need to buy 2 kits or is one kit enough for both speakers.
Asked by: SOVA
One kit includes two foam surrounds, enough for two woofers.
Date published: 2014-05-20
Do I have to use this for a Cerwin Vega speaker? or can I just use it on any 12 basket
Asked by: Hughes1911
This will work will any woofer with a 9-5/8" diameter cone and frame that is at least 11-3/4" across.
Date published: 2014-03-10
Videos
Customer projects that include: Speaker Surround Re-Foam Repair Kit For 12" Cerwin Vega
