Speaker Surround Re-Foam Repair Kit For 12" Advent Woofer with Fiber Ring
Brand:|Part # 260-955
Use this foam surround kit to repair the extremely popular Advent pincushion style woofers of the early to mid 1970s.
$35.75
Buy 4+$32.68
Part # 260-955
Use this foam surround kit to repair the extremely popular Advent pincushion style woofers of the early to mid 1970s. Each refoam kit contains supplies to repair two speakers and includes two foam surrounds, six plastic shims, two dust caps, a plastic bottle filled with 1 oz. of specially formulated adhesive, 5 foam swabs for application of glue, and complete repair instructions.
Specifications: • Foam outside diameter: 9-5/8" • Foam inside diameter: 7-1/8" • Foam outer edge width: 7/16" • Foam inner edge width: 1/8" • Dustcap diameter: 4".
Note: This speaker surround repair kit is not designed for use with subwoofers.
  • BrandParts Express
  • Part Number260-955
  • UPC844632043468
  • Product CategorySpeaker Surround Refoam Kits
  • Unit of MeasureKT
    (6 Reviews)
  • Weight0.8184 lbs.
View similar products to the Speaker Surround Re-Foam Repair Kit For 12" Advent Woofer with Fiber Ring
in the Speaker Surround Refoam Kits product category.
Speaker Surround Re-Foam Repair Kit For 12" Advent Woofer with Fiber Ring is rated 4.5 out of 5 by 6.
Rated 4 out of 5 by from Success!Re-foamed a pair of classic Advents. Sound great; however, replacement dust caps buzz like crazy, I pulled them off and now the Advents sound geat! "Stacked" 2 sets of Advents with the top pair upside down. Amazing sound that will rival systems costing many times more.
Date published: 2015-12-27
Rated 4 out of 5 by from Excellent but a bit confusingThe product worked exactly as advertised and was relatively easy to use. The only problem was in the ordering. It's best to call them to make sure you get the right one. The first one I ordered off the web site was the wrong size!
Date published: 2010-08-19
Rated 5 out of 5 by from Excellent product!The product was easy to install by following the excellent instructions provided in the kit. The components are good quality and a perfect fit; my Advent speaker systems again sound great, probably as good as they ever did when I purchased them new many years ago. The kit seems expensive considering what is included, but it is still a very worthwhile, and highly recommended purchase that I would definitely do again if any of my speakers require a replacement surround.
Date published: 2008-12-26
Rated 5 out of 5 by from Kit works perfectlyThis kit works great and I didn't worry about the dust cover as the old one was fine. If you want to keep the original sound instead of replacing the woofer this kit is for you. Henry Kloss would approve.
Date published: 2008-08-08
Rated 5 out of 5 by from Dahlquist DQ10 speaker rebuild.This kit did an excellent job of restoring the original driver to it's full potential. Be sure to use the shims and align the speaker cone down on a flat table. The surrounds should roll inward (backwards from normal). This method gave perfect results.
Date published: 2008-05-21
Rated 4 out of 5 by from Advent surrounds for masonite woofersSurrounds fit perfect but the dust covers are much larger than stock.
Date published: 2007-10-23
  • 2016-02-12T06:34CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_260-955, PRD, sort_mostRecent
I have 4 ea TechniCoustic U-1240PD speakers where the outer rim on all speakers totally disintegrated. They are 12" poly, 10 7/8" outer cone dia., 9 1/2" inner dia. Does any of your kits possibly work for repairing these speakers? Thanks much, Doug C
Asked by: drcook
Date published: 2014-12-31
  • 2016-02-12T07:04CST
  • loc_en_US, sid_260-955, PRD, sort_recentQuestionsFirst
Videos
