Speaker Surround Re-Foam Repair Kit For 11" AR Woofer
Brand:|Part # 260-972
This kit will repair the foam surrounds found on popular AR-3 speaker systems from Acoustic Research. The surrounds in this kit are exact replacements for 11" Acoustic Research woofer, so your AR-3 system will sound as good as it did when it was new from the factory.
$29.95
Buy 4+$26.25
Part # 260-972
This kit will repair the foam surrounds found on popular AR-3 speaker systems from Acoustic Research. The surrounds in this kit are exact replacements for 11" Acoustic Research woofer, so your AR-3 system will sound as good as it did when it was new from the factory. This refoam kit contains supplies to repair two speakers and includes two foam surrounds, plastic shims, two dust caps, 1 oz. of adhesive, five foam swabs for application of glue, and complete repair instructions.
Specifications: • Foam outside diameter: 10-3/8" • Foam inside diameter: 7-7/8" • Foam outer edge width: 1/4" • Foam inner edge width: 3/8" • Dustcaps: 2-3/4".
Note: This speaker surround repair kit is not designed for use with subwoofers.
  • BrandParts Express
  • Part Number260-972
  • UPC844632043451
  • Product CategorySpeaker Surround Refoam Kits
  • Unit of MeasureKT
    (6 Reviews)
  • Weight0.84 lbs.
Speaker Surround Re-Foam Repair Kit For 11" AR Woofer is rated 4.6667 out of 5 by 6.
Rated 5 out of 5 by from Worked Perfectly.Replacement parts worked perfectly - fit and quality. How to video was very helpful. Woofers are back to original performance.
Date published: 2014-07-01
Rated 5 out of 5 by from great quality productKit was complete and very easy to install. It restored my AR3 to new condition and I am now enjoying them after 20 years of storage. I still can't believe how cheap it was to restore them.
Date published: 2014-05-27
Rated 4 out of 5 by from Thanks for the quick service.The product was fine, the idiot who ordered it just got the incorrect size!
Date published: 2009-10-01
Rated 5 out of 5 by from re-surround of AR-3a woofer.I have about twenty AR 12inch woofers to re-surround and I feel this kit is one of the best to use.In fact they for all intents the foam looks exactly as my speakers looked when new back in '72.A very good and complete kit.FM
Date published: 2009-03-04
Rated 4 out of 5 by from Perfect match for AR 12 (11) inch 3a WooferWould be perfect if it had replacement cardboard gasket to maintain original surround height. I don't know if they are available anywhere though.
Date published: 2008-11-19
Rated 5 out of 5 by from my 1970's AR-11's are back!everything I needed to complete repair, easy to do, great to be able to refurbish these classic older speakers.
Date published: 2008-07-16
  • 2016-02-09T06:29CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_260-972, PRD, sort_mostRecent
I need a speaker foam replacement kit for AR 9 tower speakers.  Do you sell kits for an AR9?
Asked by: Bluemoon
We do not have a kit specific for the AR9 although we may have something that will work. If you would, email or call our tech support for more information. tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-07-08
Is my AR3a woofer a 11'' or 12''. The foam measures 11'' and outer rim measures 12'' Please give me the correct part number..... thanks
Asked by: bigjohn2
This kit is designed for a woofer with an outer rim that measures 11". You may want to consider our general purpose 12" kit which is below. This fits a frame that is 12" and a cone that is 9-1/8" to 9-1/2".http://www.parts-express.com/speaker-surround-re-foam-repair-kit-for-12-speaker--260-930
Date published: 2014-05-12
does this have 5/8 roll width (16mm)?
I've been advised that the correct O.D. should be 10.5, this one is 10 3/8. How much of a difference would that make? Also, is the roll width on this surround 16mm or 19mm?
Asked by: OuterSpaceBass
The width of the roll on this kit is ~13/16" or 19mm. The 1/8" different in the overall diameter should not make or break whether this will work or not, these kits have a 10% or so tolerance.
Date published: 2013-09-23
  • 2016-02-09T07:01CST
  • loc_en_US, sid_260-972, PRD, sort_recentQuestionsFirst
Videos
