Speaker Surround Re-Foam Repair Kit For 10" Speaker
Brand:|Part # 260-925
Don't throw away expensive loudspeakers just because the foam surround has dry rotted, or has been punctured. With these new refoam kits from Parts Express, you can save BIG bucks by repairing the foam surround and avoid costly loudspeaker replacements.
$29.80
Buy 4+$27.50
Part # 260-925
Don't throw away expensive loudspeakers just because the foam surround has dry rotted, or has been punctured. With these new refoam kits from Parts Express, you can save BIG bucks by repairing the foam surround and avoid costly loudspeaker replacements. The kit includes two pairs of foam surrounds (with two different "lip" profiles, flat and angled), two pairs of dustcaps (paper and plastic), 1 oz. of adhesive (specially formulated for various speaker cone materials), five foam swabs for application of glue, and complete repair instructions. A utility knife and isopropyl alcohol are recommended to remove old foam material, but are NOT included in this kit.
Specifications: • Foam outside diameter: 9-1/2" • Foam inside diameter: 7-1/8" • Foam outer edge width: 1/4" (flat surround), 7/16" (angled surround) • Foam inner edge width: 1/8" (flat surround), 1/4" (angled surround) • Roll width: 1/2" (flat surround), 9/16" (angled surround) • Dustcap diameter: 3".
Note: This speaker surround repair kit is not designed for use with subwoofers.
  • BrandParts Express
  • Part Number260-925
  • UPC844632043437
  • Product CategorySpeaker Surround Refoam Kits
    (56 Reviews)
  • Weight0.8184 lbs.
View similar products to the Speaker Surround Re-Foam Repair Kit For 10" Speaker
in the Speaker Surround Refoam Kits product category.
Speaker Surround Re-Foam Repair Kit For 10" Speaker is rated 4.4286 out of 5 by 56.
Rated 5 out of 5 by from EXCELLENT AS USUALI run an engineering company that specializes in high end audio builds and modifications. Our R&D department uses a myriad of different components for research. Many of the items we use are in need of repair that we do in house. Parts Express has many of the items we need for repair or modifications!These loudspeaker re-foam kits have always been high quality at a great price.
Date published: 2015-09-27
Rated 5 out of 5 by from Easy to install and looks great!Bought these for my Marantz Imperial 9's, and I couldn't be happier. Easy to install, and they brought my cabinets back to life!
Date published: 2015-02-27
Rated 5 out of 5 by from easy fixI bought the wrong size 10inch and had to return for 12inch, had no problems installing the speaker repair. Worked Great
Date published: 2015-01-20
Rated 5 out of 5 by from Easy to useI bought this kit a couple of weeks ago and spent a couple of hours repairing my old Advent speakers. The directions were spot on making the whole process fast and simple. The results of the repair make the speakers sound and look like new and at a fraction of the cost of replacing the speakers.
Date published: 2015-01-16
Rated 5 out of 5 by from great restoreI bought this surround replacement kit a few weeks ago and installed them in my Advent speakers that I purchased sometime in 1976 or early 1977. The original surrounds as you can imagine just rotted away, Go figure. lolThe instructions were easy to follow and everything was supplied and it was pretty simple especially for a person like me who doesn't do this electronic repair thing if ya know what I mean.The speakers sound great just like new only 38 years later!!!!
Date published: 2014-10-25
Rated 5 out of 5 by from worked well for meUsed this kit to bring back to life some 35 year old Kenwood woofer's, was a time consuming job removing old glue and foam from the speaker basket, but with some patience I am happy with the end result, speakers sound wonderful now!
Date published: 2014-09-26
  • 2016-02-13T06:42CST
  • co_hasreviews, tv_0, tr_56
  • loc_en_US, sid_260-925, PRD, sort_mostRecent
My woofer has a 7 1/4 interior diameter on the foam. Will this being a slightly smaller diameter making it seat slightly over the edge of the cone cause a problem will installation or, more importantly, sound quality? Thanks for your time
Asked by: gmanoc1
If the inner dust cover looks ok is it necessary to cut and remove it when replacing the outer foam speaker surround with your kits?
Asked by: LarryMatthews
Yes we still recommend removing it. The dust caps need to be removed in order to shim the cone, keeping it centered in the voice coil which allows for clean movement.
Date published: 2015-12-30
Hello! Would U have 2 foam surr. for woofers of my OLD BIC speakers? Chassis outer diam.: 253 mm (9.8 ''); chassis inner diam.: 228 mm (9 ''); cone diam.: 199 mm (7,8 ''). None of four 10 '' kits fits. Thank you for your answer/advice. Christian
Asked by: ChrisMetzFrance
Unfortunately we do not have a kit that will fit this driver.
Date published: 2015-12-14
Are these flat or angle attach foams? Thanks! Geoff
Asked by: gdeihl
This kit includes two flat and two angled surrounds.
Date published: 2015-10-23
Hello, I was wondering if you have these kits in rubber surround material?
Asked by: Rokcney
Unfortunately our kits are only available in foam.
Date published: 2015-09-21
infinity 6 kappa reference series 10inch speakers. Will the universal 10" refoam kit work? The rings are dri rotted on mine.
Asked by: Truck7766
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-08-24
  • 2016-02-13T07:41CST
  • co_hasquestionsanswers, tq_24
  • loc_en_US, sid_260-925, PRD, sort_recentQuestionsFirst
Videos
