Speaker L-Pad Attenuator 50W Stereo 1" Shaft 8 Ohm
Brand:|Part # 260-260
L-pads adjust the relative volume of drivers connected to them by placing added resistance in series and parallel, keeping impedance a constant 8 ohm load. This stereo L-pad is rated at 50 watts RMS, is designed to be used with two 8 ohm loads, features a 1" shaft length, and comes with mounting hardware.
$19.16
Buy 10+$17.03
Part # 260-260
  • Easy level adjustment for two 8 ohm loads without changing impedance
  • Great for speaker design tweaking
  • Maintains 8 ohm impedance
  • Mounting hardware included
L-pads adjust the relative volume of drivers connected to them by placing added resistance in series. At the same time, a counter-resistance is placed in parallel with the driver to maintain a constant impedance which allows the original crossover design to be used. L-pads are to be placed in between the amplifier and speaker, or in between the crossover and driver. This particular L-pad is rated at 50 watts RMS, is designed to be used with two 8 ohm loads, features a 1" shaft length, and comes with mounting hardware, faceplate, and control knob.
L-Pad Instruction Diagram
L Pad Instruction Diagram
  • BrandParts Express
  • Part Number260-260
  • UPC844632017049
  • Product CategorySpeaker L-pads
    (9 Reviews)
  • Weight0.396 lbs.
View similar products to the Speaker L-Pad Attenuator 50W Stereo 1" Shaft 8 Ohm
in the Speaker L-pads product category.
Speaker L-Pad Attenuator 50W Stereo 1" Shaft 8 Ohm is rated 4.1111 out of 5 by 9.
Rated 2 out of 5 by from unit failed after only three monthsThis l-pad worked ok for just three months before the problems started. It would never cut the output all the way. After three months it suffered an internal short. This caused it to damage two different amplifiers output on the left channel. I thought the first amp just failed from many years of use but the second much newer amp failed as well. A cheap plastic part separating the two channels inside it failed caused the short.
Date published: 2015-11-22
Rated 5 out of 5 by from Nice quality L-padBought this for a passive subwoofer project to be able to adjust the satellite speakers volume control with the high pass crossover network.Bench tested and works great! Sprayed deoxit gold on contacts in hopes of eliminating future issues.
Date published: 2015-03-02
Rated 5 out of 5 by from good purchaseI own a number of these, and have had very few problems with them. They are easy to install and solder. Only one has had a static problem; which I fixed with tuner spray cleaner. They are a good quality item and are more than reasonably priced.
Date published: 2014-07-01
Rated 4 out of 5 by from L-pad, 50watt Stereo control, 8 OhmThis unit fit our application well & was an easy install.
Date published: 2013-09-04
Rated 4 out of 5 by from Great little LPadI needed a level control for a 4 ohm driver and this one, with the terminal wired in parallel, worked nicely! This unit can handle a fair amount of power, not obvious problems with it, I like it for general duty uses. It is a good idea to spray lube in it for the long use to prevent the dreaded scratchiness they all will get!
Date published: 2009-03-08
Rated 4 out of 5 by from Works great, solder lugs too smallPerforms its job perfectly. Sadly, the solder lugs are too small for braided wire of sufficient size to properly support 50W speakers. Had to jury-rig wire connections.
Date published: 2009-01-19
  • 2016-02-10T06:45CST
  • co_hasreviews, tv_0, tr_9
  • loc_en_US, sid_260-260, PRD, sort_mostRecent
It's rated at 8 ohms, but can I use a 4 + 8 ohm load?
Asked by: Limo
The L-pad is only rated to work with 8 ohm loads, so the 4 ohm load you refer to in your question would not be compatible.
Answered by: GregT
Date published: 2015-11-18
Is dimension information available?
It would be helpful in selecting a project pox and other project considerations.
Asked by: wedge
Not including the shaft, this unit is approximately 2 x 2 x 2 inches.
Answered by: RussR
Date published: 2011-05-02
  • 2016-02-10T07:44CST
  • loc_en_US, sid_260-260, PRD, sort_recentQuestionsFirst
