Speaker L-Pad Attenuator 15W Stereo 1" Shaft 8 Ohm
Brand:|Part # 260-251
L-pads adjust the relative volume of drivers connected to them by placing added resistance in series and parallel, keeping impedance a constant 8 ohm load. This stereo L-pad is rated at 15 watts RMS and is designed to be used with two 8 ohm loads. Features a 1" shaft length. Comes with mounting hardware, faceplate, and knob.
OUT OF STOCK
Due In: 3/10/2016
$11.28
Buy 10+$9.99
Part # 260-251
  • Easy level adjustment of two 8 ohm loads without changing impedance
  • Great for speaker design tweaking
  • Maintains constant 8 ohm impedance
  • Mounting hardware included
L-pads adjust the relative volume of drivers connected to them by placing added resistance in series. This stereo L-pad is rated at 15 watts RMS per L-pad and is designed to be used with two 8 ohm loads. Features a 1" shaft length. Comes with mounting hardware, faceplate, and volume control knob.
L-Pad Instruction Diagram
L Pad Instruction Diagram
  • BrandParts Express
  • Part Number260-251
  • UPC844632018442
  • Product CategorySpeaker L-pads
    (9 Reviews)
  • Weight0.15 lbs.
View similar products to the Speaker L-Pad Attenuator 15W Stereo 1" Shaft 8 Ohm
in the Speaker L-pads product category.
Speaker L-Pad Attenuator 15W Stereo 1" Shaft 8 Ohm is rated 3.8889 out of 5 by 9.
Rated 4 out of 5 by from Exactly as advertised.Terminals are very weak and easy to break off. Be careful. Other than that the operation is great.
Date published: 2014-07-29
Rated 5 out of 5 by from 260-251 stereo L-padI bought 4 of these to use in conjunction with another PE product--the Vifa BC255C06-04(4 ohm) tweeter. I have some 2 and 3 way speakers that utilize these tweeters. The Vifas have a high SPL per watt compared to many woofers and midranges. After listening to them and reading some of the reviews, I knew that an attenuating device was needed. Using 18 guage primary wire available in several colors from Adv---- auto parts, I wired the two pads of the 260-251 in parallel to tame the output of the 4 ohm Vifas without affecting their crossover point. It balanced the overall sound of my 2 & 3 way speakers. Strip about 1 1/4", wind the 18AWG wires slightly and carefully pass them through the pad terminal holes, then solder. I will be ordering more of these.
Date published: 2013-10-15
Rated 4 out of 5 by from Work as DescribedThese L-Pads work great on a recent Radio Station build. The L-Pads work great for headphone volume control for DJ's and other guests.
Date published: 2009-11-08
Rated 1 out of 5 by from Useless for Pachislo or Slot MachinesEven at the lowest setting it is too loud... Shipping is more than the product costs..
Date published: 2009-09-17
Rated 4 out of 5 by from Nice L PadI needed a level control for a 4 ohm driver and this one, with the terminal wired in parallel, worked nicely! This unit can handle a fair amount of power, not obvious problems with it, I like it for general duty uses. It is a good idea to spray lube in it for the long use to prevent the dreaded scratchiness they all will get!
Date published: 2009-03-08
Rated 5 out of 5 by from Great product at a great priceUsing this lpad for volume control on a Sankyou pachinko game and it works really well. Finally able to play the game without going deaf!
Date published: 2009-02-13
  • 2016-02-08T06:29CST
  • co_hasreviews, tv_0, tr_9
  • loc_en_US, sid_260-251, PRD, sort_mostRecent
Could I wire these to a 4 ohm, 3 watt, speaker load?  Would they work as intended?  If not, what would happen? Thanks!
Asked by: SeanMcCauley
  • 2016-01-22T07:32CST
  • co_hasquestions, tq_1
  • loc_en_US, sid_260-251, PRD, sort_recentQuestionsFirst
