260-264_ALT_0
260-264_ALT_1
Speaker L-Pad Attenuator 100W Stereo 1" Shaft 8 Ohm
L-pads adjust the relative volume of driver(s)/speaker(s) connected to them by placing added resistance in series. This L-pad is rated at 100 watts RMS, is designed to be used with 8 ohm loads, features a 1" shaft length, and comes with mounting hardware, faceplate, and knob.
260-264
Weight: 0.7194 lbs.
IN STOCK
$24.80
Buy 10-up$22.00
Part # 260-264
L-pads adjust the relative volume of driver(s)/speaker(s) connected to them by placing added resistance in series. At the same time, a counter-resistance is placed in parallel with the driver(s)/speaker(s) to maintain a constant impedance which allows the original crossover design to be used. L-pads are to be placed in between the amplifier and driver(s)/speaker, or in between the crossover and driver(s)/speaker(s). This particular L-pad is rated at 100 watts RMS, is designed to be used with 8 ohm loads, features a 1" shaft length, and comes with mounting hardware, faceplate, and volume control knob.
Dimensions: 2-1/2" diameter, 2" depth.
L-Pad Instruction Diagram
L Pad Instruction Diagram
  • BrandParts Express
  • Part Number260-264
  • UPC844632017759
  • Product CategorySpeaker L-pads
    (4 Reviews)
  • Weight0.7194 lbs.
View similar products to the Speaker L-Pad Attenuator 100W Stereo 1" Shaft 8 Ohm
in the Speaker L-pads product category.
Speaker L-Pad Attenuator 100W Stereo 1" Shaft 8 Ohm is rated 4.5 out of 5 by 4.
Rated 5 out of 5 by from PerfectThe product did exactly what I needed, recommended by kicker I am completely satisfied with it. !5 minute install and that was the end of it!
Date published: 2012-03-24
Rated 4 out of 5 by from very functional but the lowest levels are unsmoothThe product works well except at the very lowest levels. There the left and right volume levels become unmatched. Aside from that it works very well. It does not consistently keep 8 ohms but never goes lower than 8 ohms.
Date published: 2008-10-09
Rated 5 out of 5 by from A Good Double L-PadUsed this product on a double 4 ohm speaker set up to balance with- worked beautifully!
Date published: 2008-07-13
Rated 4 out of 5 by from High quality L-PadThis L-Pad is well constructed and performs as it should. Operation is smooth.
Date published: 2008-01-22
What are the dimensions of this device excluding the terminals? Is it 2.5 inches which is the circular part of the L-Pad. It would be nice to have a drawing to show the dimensions.
Asked by: JimN
Yes the body of the L-pad is 2-1/2" in diameter excluding the terminals.
Date published: 2014-06-25
Can you somehow wire this up to handle 200W RMS, e.g. wiring the two "channels" in parallel or series?
Asked by: kuruption
If you wire both pots in parallel you will double their power handling.
Date published: 2013-10-15
What happens at 4 ohms?
I need to attenuate a set of 4 ohm monitor speakers to match the other sets of speakers I use for mix references. I have an amp that has A/B sets of outputs, but only one set of level controls. The 4 ohm Behringer C1s are much louder than my Yamahas (which are set to match perfectly with the Alesis M1s driven by another amp).Will the 8 ohm L-pad work with 4 ohm speakers? What will happen? I don't see any 4 ohm L-pads.
Asked by: Bushman
it sounds like your planning to use it pre any passive xo...this would demand a fairly massive wattage de-rateing of the L-pad in that application..also, that load would half the wattage rating to start..personally, i would suggest an active solution.
Answered by: rulgert
Date published: 2012-03-05
Customer projects that include: Speaker L-Pad Attenuator 100W Stereo 1" Shaft 8 Ohm
