260-261_ALT_0
260-261_ALT_1
Speaker L-Pad Attenuator 100W Mono 3/8" Shaft 16 Ohm
L-pads adjust the relative volume of driver(s)/speaker(s) connected to them by placing added resistance in series. This L-pad is rated at 100 watts RMS, is designed to be used with 16 ohm loads, features a 3/8" shaft length, and comes with mounting hardware, faceplate, and knob.
  • Add volume controls to any speaker
  • Great for speaker design tweaking
  • Maintains 16 ohm impedance
  • Mounting hardware included
260-261
Weight: 0.708 lbs.
IN STOCK
$12.95
Buy 10-up$11.60
Part # 260-261
L-pads adjust the relative volume of driver(s)/speaker(s) connected to them by placing added resistance in series. At the same time, a counter-resistance is placed in parallel with the driver(s)/speaker(s) to maintain a constant impedance which allows the original crossover design to be used. L-pads are to be placed in between the amplifier and driver(s)/speaker, or in between the crossover and driver(s)/speaker(s). This particular L-pad is rated at 100 watts RMS, is designed to be used with 16 ohm loads, features a 3/8" shaft length, and comes with mounting hardware, faceplate, and volume control knob.
Dimensions: 2.5" diameter, 1-1/8" depth.
L-Pad Instruction Diagram
L Pad Instruction Diagram
  • BrandParts Express
  • Part Number260-261
  • UPC844632018480
  • Product CategorySpeaker L-pads
    (1 Reviews)
  • Weight0.708 lbs.
View similar products to the Speaker L-Pad Attenuator 100W Mono 3/8" Shaft 16 Ohm
in the Speaker L-pads product category.
Speaker L-Pad Attenuator 100W Mono 3/8" Shaft 16 Ohm is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Excellent quality L-pad with unexpected featuresI purchased two of these L-pads to replace worn, scratchy L-pads used as treble and midrange tone controls on a classic Electro-Voice Georgian corner horn monaural speaker system.The first thing I noticed upon unboxing these L-pads is the excellent feel and build quality. The second thing I noticed was that they come with an escutcheon and knob, however I chose not to use them in favor of 260-274 Dual L-Pad Face Plate Vertical.I did not expect the anti-rotation post, which engages with a matching hole in the escutcheon. Also, the shafts are grooved and the knobs fit snugly.Performance is outstanding - absolutely noiseless electrically. The adjustment occurs in small discrete increments due to the internal motion of the wiper over the windings. Infinite adjustment is not possible however in my application this was irrelevant.
Date published: 2012-02-06
Could you please advise me as to whether this is a suitable replacement for a 14 ohm potentiometer in an Acoustic Research AR 2ax speaker crossover network? Is the potentiometer wire wound? Thanks...
Asked by: Neilbar
Yes this will work fine as a replacement for that. These are wire wound.
Date published: 2014-01-30
Customer projects that include: Speaker L-Pad Attenuator 100W Mono 3/8" Shaft 16 Ohm
