260-346_ALT_0
260-346_ALT_1
260-346_ALT_2
260-346_ALT_3
260-346_ALT_4
Speaker Grill Frame Kit
Product Video
This interlocking grill frame kit is just what you need to replace your old worn out speaker grills, or to put that finishing touch to your new speaker project. All pieces fit together tightly and are made of rugged plastics so even the largest grills are possible.
  • Tight-fit interlocking assembly
  • Rugged construction for even the largest speakers
  • Great for large PA or vintage speakers
  • Easy-to-follow illustrated instructions
  • Extra corners and T-joints available separately
260-346
Weight: 1.6 lbs.
IN STOCK
List Price$23.99
You Save25%
$17.96
Buy 4-up$16.98
Part # 260-346
To prevent misalignment of sockets, pilot holes are provided in each corner plug. These holes can also be used to put the original brand badging or your own personal logo adding the finishing touch to your project. Each kit comes complete with 4(42") - frame rails, 4 - corners, 4 - sockets, 2 - T– joints, 1(42") - crossbrace and easy to follow illustrated instructions. All you need is to apply your choice of grill cloth (sold separately). NOTE: One kit can make a grill frame as large as 46-1/2" x 45-1/4". If you require a grill frame less than 23" x 22" two grill frames can be made from just one kit all you need is a corner kit and maybe a T-joint kit (sold separately).
  • BrandParts Express
  • Part Number260-346
  • UPC844632085857
  • Product CategoryGrill Frame Kits
    (20 Reviews)
  • Weight1.6 lbs.
View similar products to the Speaker Grill Frame Kit
in the Grill Frame Kits product category.
Speaker Grill Frame Kit is rated 4.65 out of 5 by 20.
Rated 5 out of 5 by from GRILL KITEASY TO CUT AND ASSEMBLE. LOOKS GREAT. BEATS DOING IT THE OLD FASHIONED WOOD FRAME WAY. GOES ON AND OFF EASILY WITH THE RUBBER GOUMETS.
Date published: 2014-10-17
Rated 5 out of 5 by from Easy to build, looks greatI needed to make grills for two small subwoofers, each about 13x13. I bought this kit, along with a corner kit and fabric. Using this kit I was able to make both grills and I had an entire stick left over for a future project. It went together easy, the runners cut easily with a craft knife and it was pretty obvious how it went together. I went from parts to grills in about twenty minutes, excluding covering. My only suggestion would be to mold in a very thin channel on the rear of the runners to insert the grill fabric into, rather than use glue.
Date published: 2014-08-26
Rated 5 out of 5 by from Quick and easy way to replace speaker grills.This grill kit couldn't be any easier to assemble, I had my monkey do it for me. It does exactly what it's intended to. Leave just a little loose to allow for the thickest of the grill cloth.
Date published: 2014-05-03
Rated 5 out of 5 by from Making new grills is easyI used a 4 of these kits to make a new pair of grills for a pair of Infinity QLS1 speakers. Everything worked well and the result looks professional. Just be sure not to stretch the grill cloth too tight or you will bend the straight sections of the frame if they are long. Recommended product.
Date published: 2014-02-25
Rated 5 out of 5 by from GrrriilllllBought this to finish a theater room in wall speaker system. Simple, easy and terrific looking system.
Date published: 2014-01-31
Rated 4 out of 5 by from Speaker GrillThe speaker grill kit is easy to use and provides excellent results. It saves time but is a little expensive
Date published: 2013-08-10
how long are the long pieces? Are they the same length?
Asked by:
Each long section is 24" in length, they are all the same. They are designed to be cut to custom lengths in order to match up with the cabinet dimensions you are making a grill for.
Date published: 2014-10-28
How do you attach the speaker cloth to these frames ---- I get that the frame itself is easy to make -- but looking at the rails - I see no way to attach the cloth --- someone mentioned glue = Really?? - I would think a channel to clamping piece -----
Asked by: Bill 3333
We recommend hot melt glue for attaching the grill cloth to this kit.
Date published: 2014-10-21
How much space should there be between the mounted driver and the edge of the speaker cabinet for the grill to sit comfortably?  Thanks!
Asked by: Prem
I would recommend a minimum of 3/4" around the edges of the drivers in order for this grill to sit flush.
Date published: 2014-09-02
Is it possible to make a 64 inch wide speaker grill with this kit to cover my speakers that sit below my 70 in TV in a custom cabinet with areas that I had made to look like a sound bar where the speakers sit? (64" W X 6" H). Thank you
Asked by: BucolicBumpkin
This is only capable of making grills up to 46-1/2 inches by itself, but you can use the additional t joints to add some length .http://www.parts-express.com/speaker-grill-frame-t-joint-kit-2-pcs--260-349
Answered by: Chrisf
Date published: 2014-06-06
how thin is the grill kit, i.e. when mounted how far does it extruded from the speaker box.
Asked by: cirrusfrost
The grill when finished is 3/4" thick.
Date published: 2014-02-03
Measurement from Pin to Corner
Would it be possible to get a measurement from the center of the pin to the corner? I have a set of speakers missing their grills, and I'd like to know if this kit would work with them without having to drill a second set of holes to hold the grill.
Asked by: RobCan
The distance from the center of the pin to the corner is 1-1/4".
Date published: 2013-07-09
Videos
Customer projects that include: Speaker Grill Frame Kit
