260-540_ALT_0
260-540_ALT_1
260-540_ALT_9
Speaker Gasketing Tape 1/8" x 3/8" x 50 ft. Roll
Finally! A foam gasketing tape designed specifically for loudspeakers! This specially designed foam tape is excellent for making an airtight seal around drivers, terminals, handles, horn lenses, or any other item that needs installed in your cabinet!
260-540
Weight: 0.45 lbs.
IN STOCK
List Price$12.99
You Save39%
$7.90
Buy 4-up$7.45
Part # 260-540
Qty:  RL
Finally! A foam gasketing tape designed specifically for loudspeakers! This specially designed foam tape is excellent for making an airtight seal around drivers, terminals, handles, horn lenses, or any other item that needs installed in your cabinet! The closed cell PVC foam is a dark charcoal color that eliminates unsightly bright-colored seams, while the high-tack adhesive aggressively sticks to all speaker frames-- unlike the "gray stuff" from your hardware store. The 3/8" width can be used on drivers as small as 3"; use the 1/2" width for larger 10's, 12's, 15's, and 18's. 1/8" thick, sold in 50 ft. rolls.
  • BrandParts Express
  • Part Number260-540
  • UPC844632043017
  • Product CategoryGasketing Tape / Caulk
  • Unit of MeasureRL
    (50 Reviews)
  • Weight0.45 lbs.
View similar products to the Speaker Gasketing Tape 1/8" x 3/8" x 50 ft. Roll
in the Gasketing Tape / Caulk product category.
Speaker Gasketing Tape 1/8" x 3/8" x 50 ft. Roll is rated 4.72 out of 5 by 50.
Rated 5 out of 5 by from Good to keep some on hand.I love having extra gasket tape around the house. I bought this after ordering the Jung 500 watt sub plate amp. I used it to keep my sealed home theater sub box air tight when install ing the plate amp and subwoofer. Since then I have picked up some thrift store 2 way and 3 way speakers. While I have the drivers out of their enclosures to check conditions of crossovers and sound dampening; I make sure to install/ re-install gasket tape around drivers to insure proper seals with enclosure. For P.E.s price you get a large amount of gasket tape and it is of great quality. Thanks P.E!
Date published: 2014-02-09
Rated 5 out of 5 by from Awesome productI used this product to complete my sealed subwoofer enclosure. Easy to work with and I have plenty of extra for future projects.
Date published: 2014-02-04
Rated 5 out of 5 by from Parts Express - Speaker Gasketing Tape 1/8" x 3/8"I purchased about a month ago. My speakers were leaking air from the front of the cabinet. I used the product and it cleared up the problem. The tape is Inexpensive andworks well. My only suggestion is to find another way to package and dispense but; this is minor and has nothing to do with the product quality
Date published: 2014-01-24
Rated 5 out of 5 by from Super seal!Seriously, this tape seals like nobody's business! Because it's closed cell foam, you'll have to let the foam "re-inflate" (takes a long time) or try to remove it if you want to transfer the driver to another cab. Good luck with the latter option, the adhesive is tenacious! But it's the best foam I've used!
Date published: 2013-04-14
Rated 5 out of 5 by from tight sealsealed up the ten inch in my bass amp, air leaks are gone and the sound isbetter
Date published: 2013-03-22
Rated 5 out of 5 by from Great StuffThe 50 foot rool is plenty to do large speaker boxes. The foam was a little thick in my opinion but it will serve to create a great seal on even a textured particle board type surface.Referring back to the thickness however, if you are gasketing flush mount speakers like tweeters this may be a little too thick for you. I used it with flush tweeters and left a small 1/16" gap between the tweet and the cabinet from fear of cracking the plastic.
Date published: 2013-02-01
I'm building a cooler radio and was wondering if using this gasket tape around my 6x9's would work to keep water out of the cooler while floating the river. It won't be submerged, its more for the random splashes of water it will take on. Thanks
Asked by: Johnny11805
This gasketing tape is not specifically intended for an application like that, however it is closed-cell foam so it should not soak up water like a sponge. I see no reason for it not to work.
Date published: 2014-03-18
Extra depth to recess?
Would I need to add a bit to the the depth of the recessed cuts to allow for flush mounting?
Asked by: Just A Noobie
I've used this gasket tape on two projects. I found that it compresses down to about 1/16". So if you want to add a little extra depth to the recess I wouldn't add more than 1/16".
Answered by: JimOfOakCreek
Date published: 2012-05-20
Customer projects that include: Speaker Gasketing Tape 1/8" x 3/8" x 50 ft. Roll
