260-542_ALT_0
Speaker Gasketing Tape 1/8" x 1/2" x 50 ft. Roll
Finally! A foam gasketing tape designed specifically for loudspeakers! This specially designed foam tape is excellent for making an airtight seal around drivers, terminals, handles, horn lenses, or any other item that needs installed in your cabinet!
260-542
Weight: 0.55 lbs.
IN STOCK
List Price$13.99
You Save39%
$8.44
Buy 4-up$7.66
Part # 260-542
Qty:  RL
Finally! A foam gasketing tape designed specifically for loudspeakers! This specially designed foam tape is excellent for making an airtight seal around drivers, terminals, handles, horn lenses, or any other item that needs installed in your cabinet! The closed cell PVC foam is a dark charcoal color that eliminates unsightly bright-colored seams, while the high-tack adhesive aggressively sticks to all speaker frames-- unlike the "gray stuff" from your hardware store. The 3/8" width can be used on drivers as small as 3"; use the 1/2" width for larger 10's, 12's, 15's, and 18's. 1/8" thick, sold in 50 ft. rolls.
  • BrandParts Express
  • Part Number260-542
  • UPC844632043000
  • Product CategoryGasketing Tape / Caulk
  • Unit of MeasureRL
    (33 Reviews)
  • Weight0.55 lbs.
View similar products to the Speaker Gasketing Tape 1/8" x 1/2" x 50 ft. Roll
in the Gasketing Tape / Caulk product category.
Speaker Gasketing Tape 1/8" x 1/2" x 50 ft. Roll is rated 4.7576 out of 5 by 33.
Rated 5 out of 5 by from Perfect for subsI use this to put a good seal on my subs before mounting them into my box
Date published: 2014-03-26
Rated 5 out of 5 by from great stuff! stop reading after this, and buy it!i have bought similar products to this before, and was not sure what to expect when it said "pvc foam"! then it shows up, and it's high quality neoprene...very cool
Date published: 2013-09-30
Rated 5 out of 5 by from Nice seal, easy to useI used this tape to seal up some 15" pro audio drivers going in a cabinet. Once the adhesive backing is removed, it bends very easily and is quite easy to install. The 50' rolls I purchased will probably last me over the next year or so!One piece of caution though - I had to remove the drivers which I recently installed for a crossover change, and the drivers were so well sealed they did not come out so easily! Some of this can be attributed to the fact that the cutout was pretty snug, but the gasket also seemed to cling to the baffle quite firmly. Just doing it's job I guess!
Date published: 2013-02-05
Rated 5 out of 5 by from Best Speaker Gasketing MaterialThe Speaker Driver-to-Enclosure Interface is so important that Fastener Torque alone has dramatic impact on loudspeaker performance (several dB) and this impact is measurable, audible and well-documented (see Loudspeaker Design Cookbook).I can recommend PE's "Speaker Gasketing Tape" without reservation because I have found it to be a completely effective product.One side of the gasketing tape is coated with a very aggressive adhesive, so once placed on the speaker driver's flange it stays on place during assembly, so its easy to use.The gasketing tape is made from closed-cell foam, so once the fasteners are properly torqued, the gasketing tape does not continue to compress over time. It provides a very dense but resilient gasket interface between driver and enclosure and it maintains this interface quality indefinately.**note: remember that the Speaker Gasketing Tape does not compress completely and requires a very slight increase in driver inset depth when routing your enclosure for flush-mounting your drivers.
Date published: 2013-09-29
Rated 5 out of 5 by from Good Stuff!Used this on my 6.5" mids and I love 'em. A lot cheaper than comparable products from other companies. One roll goes a long way. I did 4 mids and it doesn't seem like the roll has been touched. The adhesive is excellent and the foam conforms well to the speaker...
Date published: 2012-09-24
Rated 5 out of 5 by from THE ROLL AND SEAL FOAMAwesome stuff i sealed off my Cerwin Vega VS100's drivers all off and they sound better you cant hear the air escaping from the side's of all the driver being pushed by the woofers great item, i have both size rolls... :)
Date published: 2012-09-02
how to you install this gasket tape ?
silly questions but how do you install it directly on the driver? if so inside or outside the screw holes? ot directly on the cut out of the sub cabinet
Asked by: Alain
I recommend applying the foam gasketing tape to the speaker cutout on your cabinet... not to the driver itself. From a construction standpoint, either way works fine... but it's just a bit easier to work with (for me, at least) if you apply it to the cabinet, instead of to the speaker. I would recommend investing in a nice set of X-acto blades, though. They're very handy for cutting and trimming foam gaskets and all sorts of other things.
Answered by: Rasterburn
Date published: 2012-02-18
thank you foe the answer, do i install the tape on the inside or outside edge of the cabinet cut out
Asked by: Alain
the tape goes on the edge, the pressure pinch point of the frame to box, then check for whistles when you apply speaker current to them
Answered by: digitalhaven 53
Date published: 2011-11-16
Customer projects that include: Speaker Gasketing Tape 1/8" x 1/2" x 50 ft. Roll
