Crossover 3-Way 8 Ohm 800/5,000 Hz 100W
Speaker Crossover 3-Way 8 Ohm 800/5,000 Hz 100W
3-way crossover for speaker designed to handle 100 watts RMS program power. Crossover frequencies of 800 Hz and 5,000 Hz with 12 dB per octave roll-off into an 8 ohm load.
  • Designed to handle 100 watts RMS program power
  • Frequencies of 800 Hz and 5,000 Hz with 12 dB per octave roll-off into an 8 ohm load
260-210
Weight: 1.0956 lbs.
IN STOCK
List Price$24.99
You Save21%
$19.50
Buy 6-up$17.00
Part # 260-210
3-way crossover for speaker designed to handle 100 watts RMS program power. Crossover frequencies of 800 Hz and 5,000 Hz with 12 dB per octave roll-off into an 8 ohm load. Dimensions: 4-3/4" W x 4" D x 1-1/8" H. Connection instructions (with crossover aligned as pictured): Top left is input positive (+), bottom left is input negative (-), bottom right is midrange positive (+), centered on the right are three output negative (-) connections, above the output negative connections is the woofer positive (+), top right is the tweeter positive (+).
  • Crossover Type3-Way
  • ConfigurationBoard Only
  • BrandParts Express
  • Part Number260-210
  • UPC844632017018
  • Product CategoryAssembled Passive Crossovers
    (63 Reviews)
  • Weight1.0956 lbs.
View similar products to the Speaker Crossover 3-Way 8 Ohm 800/5,000 Hz 100W
in the Assembled Passive Crossovers product category.
Speaker Crossover 3-Way 8 Ohm 800/5,000 Hz 100W is rated 4.4444 out of 5 by 63.
Rated 5 out of 5 by from Great crossover for projects.I have a pair of AR 707 floor monitors that had a a 3.3mfd on the tweeter and a 16mfd on the mid. I installed these and they had a much cleaner sound to them. I compared 1 with this crossover & one with the original setup side by side and got much cleaner highs with the crossover.
Date published: 2014-04-22
Rated 5 out of 5 by from Good crossoverworked really well with Part # 294-2703 for mids, woofer- 295-325 and tweeter # 275-070
Date published: 2014-04-15
Rated 4 out of 5 by from Awesome sound!i bought these crossovers because they were the cheapest 3 ways on this site, and i am so shocked at the great sound! not just me but my friend who collects vintage speakers was really surprised at the sound quality!!! only small down side was the crossover is a little high at 5k...maby? cant beat that for the price!!!
Date published: 2014-04-08
Rated 4 out of 5 by from new life to old speakersthe crossovers I replaced were 43 year old hand maids. first I upgraded the horns with new tweets and replaced the drivers and had the 15 inch subs reconditioned.I don't do a lot of soldering but I did use a small heat sink. the connections were self explanatory, took about 1 and a half hours. they now sound incredible. thanks PARTS EXPRESS! I'm now ready for another bout with these speakers.
Date published: 2014-01-21
Rated 5 out of 5 by from Great product ..great priceI have Cambridge Soundworks Tower speakers. The tweeter crossover circuit was blown from playing too loud. It blew out the caps. I installed one of these in each speaker and I feel that for my taste, they sound better than the original ones. The mid is a little bright so I use a software equalizer to turn it down as the music is playing from the HTPC system. I would definately recommend this product.
Date published: 2013-04-09
Rated 5 out of 5 by from Good budget crossover.The title really says it all. These are really solidly built with decent components. These crossovers are pretty big and heavy, too, so not very good for a small speaker project. I used these in a cheap refurb, so the price was right. Great value and good sound.I tested them before installing, just to make sure the channels are separating well, because I was worried about the solder issue. Upon examination I didn't see any solder overruns. But, someone does need to learn to solder better - whoever is assembling these uses a ton.
Date published: 2012-11-12
Will This Crossover Work In A pair of Fisher ST-843 Tower speakers
Asked by: Topher1994
Unfortunately I cannot say without knowing the original crossover points. Do you have this information available?
Date published: 2014-07-09
Where is the input for the crossover? Is it the positive and negative over on the left side?
Asked by: Nihaal
Yes, looking at the photo on our website the input is on the left side, with positive being on top and negative (common) being on the bottom.
Date published: 2014-07-02
Would these three speakers work with this crossover: (Woofer) 295-301, (Midrange) 297-433, (Tweeter) 270-176?  I'm trying to go cheep, but decent for a sound bar type application?  Any mods needed to any of the speakers post xover hookup?
Asked by: Jellis3d
Yes those drivers will work with that crossover. The only addition you might need would be an L-Pad on the tweeter to help attenuate the output level, but this will be subjective.
Date published: 2014-06-19
Can these be used in a car audio application?
Asked by: nathan87007
Yes these can be used in car audio, but only if using 8 ohm drivers.
Date published: 2014-04-04
I have a 4 way system (two mid's) from a build i did like 20 years ago. could i use this crossover to run the woofer, one mid and tweeter. then run the other mid with just it's 33ufCap? All drivers are 8 ohm. and plan on upgrading with similar drivers.
Asked by: spur31
Technically this will work although the second mid will have to be wired separately from the crossover.
Date published: 2014-03-18
How much air is displaced by one of these when put inside the cabinet?
Asked by: OxRod
While these and all crossovers take up airspace, it is not enough to hinder in terms of box volume, tuning frequency or F3 numbers. After a very quick (not ideal) calculation, this crossover takes up roughly 0.004 cubic feet, or 0.11 liters.
Date published: 2013-12-30
Customer projects that include: Speaker Crossover 3-Way 8 Ohm 800/5,000 Hz 100W
