260-329_ALT_0
Speaker Cabinet Port Tube 4-5/16" ID Adjustable
Give your cabinets a professional appearance with these attractive, black plastic port tubes. When properly tuned, the port contributes significantly to the low frequency output of the speaker system.
260-329
Weight: 0.9834 lbs.
IN STOCK
$6.50
Buy 10-up$5.85
Part # 260-329
Give your cabinets a professional appearance with these attractive, black plastic port tubes. When properly tuned, the port contributes significantly to the low frequency output of the speaker system. Outer flange diameter is 5-5/8". Cutout required is 4-3/4". Adjustable length from 6-1/4" to 11-3/4".
  • BrandParts Express
  • Part Number260-329
  • UPC844632017551
  • Product CategorySpeaker Port Tubes
    (10 Reviews)
  • Weight0.9834 lbs.
View similar products to the Speaker Cabinet Port Tube 4-5/16" ID Adjustable
in the Speaker Port Tubes product category.
Speaker Cabinet Port Tube 4-5/16" ID Adjustable is rated 4.7 out of 5 by 10.
Rated 4 out of 5 by from Here are the exact dimensionsThese flanged inner sections of these things were almost perfect for my Altec 846B Valencias, for some custom baffles I'm making. They're just a hair too long, but that's easily fixed. Here are their approximate dimensions:Wall Thickness: 1/8"Inner (flanged) sliding tube: Length: 6"; Inner Diameter: 4 5/16"; OD: 4 1/2"Outer sliding tube: Length 5 7/8"; ID: 4 9/16"; OD: 4 13/16"Flange diameter: 5 11/16"There are six holes around the flange, 5 5/16" across from each other.One end of the outer sleeve has two holes, directly across from each other, to let you run screws (not included) into the inner tube and secure the outer tube to it.
Date published: 2011-06-23
Rated 5 out of 5 by from as advertisedGreat product for tweakers and listeners like me, who tune by ear.
Date published: 2011-06-06
Rated 5 out of 5 by from bass drum port??WOW !! what a difference a port makes!! I put this in the front skin of my bass drumbecause the one of similar design for sale at music stores is $40.00 bucks. The end result is a more powerful sound with increased attack(sharpness), volume(louder), and lower frequency response(that was my goal) without paying a fortune for a piece of plastic.Parts-Express "Hit the Mark" with this one.Installation was tricky but worth it. I didn't even use the adjustable sleeve and it sounds great in my 24"x17" kick drum. I may put the other half in my bass guitar cabinet, I'm sure the end result will be the same there as well.Thanks again Parts-Express for a great product at areasonable price.
Date published: 2010-09-24
Rated 5 out of 5 by from wowim was pushing 2 performance tek's 2000 watts eachand with my sealed box they wouldn't reach peak do to the excessive pressure..when i installed the adjustable tubes and tuned it to 27 hz the sound on my music was amazing ....they hear me from a block away! and its so easy to install with a router, glue and screws . USE FOR BIG BOXES I RECOMMEND NOT TRUCK ENCLOSURES
Date published: 2010-01-04
Rated 5 out of 5 by from Makes Tuning the Port EASYInstalled in 2-15 Bass Cabinet. The tube extension makes an excellent template for cut out. Easily installed. Sounds Great.
Date published: 2009-08-28
Rated 5 out of 5 by from easily tunedThe virtual computer model of your speaker cabinet design is not always perfect. These adjustable tuning ports provide you with enough "wiggle room" to optimize the real world tuning result. I feared that they would be too fragile but they turned out to be plenty rugged during installation and operation.
Date published: 2009-06-15
Customer projects that include: Speaker Cabinet Port Tube 4-5/16" ID Adjustable
Related Products
Customers Also Bought
