300-637_ALT_0
Speaker Bar and 10" Subwoofer Package
Combine a Dayton Audio BS36 LCR speaker bar with a SUB-1000 powerful powered 10" subwoofer system and save over $40 off the combined retail price!
  • Impressive sound without an overwhelming size
  • Left, center, and right channel speakers in one beautiful package
  • The ideal front channel solution for your home theater
  • 10" 100 watt subwoofer produces impressively deep powerful bass
  • Over $40 off the combined retail price!
300-637
Weight: 49 lbs.
OUT OF STOCK
Due In: 5/7/2015
List Price$469.99
You Save54%
$218.00
Part # 300-637
The small-but-mighty Dayton Audio BS36 speaker bar that combines left, center, and right channel drivers into a single convenient mountable enclosure that can be positioned above or below the screen or sit free standing. Combined with a Dayton Audio SUB-1000 powered 10" subwoofer system to provide a home theater front stage that produces optimum sound without infringing on your room.
Dayton Audio SUB-1000 Subwoofer Specifications:  • Power output: 100 watts RMS • Frequency response: 30-140 Hz • Box design: Ported • Inputs: RCA line level & speaker level • Outputs: Speaker level • Crossover frequency control: Continuously variable from 40 Hz to 140 Hz @ 12 dB/octave • Phase switch • Auto on/off • Dimensions: 14-3/4" H x 14-3/16" W x 15-3/4" D.
Dayton Audio BS36 Speaker Bar Specifications: • Three 3-3/4" paper cone woofers • Three 5/8" aluminum tweeters • Power handling: 50 watts RMS/80 watts max • Impedance: 8 ohms • Frequency response: 100-20,000 Hz • SPL: 87 dB 1W/1m • Dimensions: 4-3/4" H x 37" W x 4-1/4" D. Note: Screw mounts and M5 threaded inserts that are designed for 16" on-center studs. Hardware sold separately. See related items for optional Hangman mounting bracket.
Speaker Bar and 10" Subwoofer Package includes the following items:
Qty Part # Item
1300-684Dayton Audio BS36 36" LCR Speaker Bar Black
1300-628Dayton Audio SUB-1000 10" 100 Watt Powered Subwoofer
  • BrandParts Express
  • Part Number300-637
  • UPC844632091421
  • Product CategorySound Bars / Speaker Bars
    (4 Reviews)
  • Weight49 lbs.
View similar products to the Speaker Bar and 10" Subwoofer Package
in the Sound Bars / Speaker Bars product category.
Speaker Bar and 10" Subwoofer Package is rated 4.5 out of 5 by 4.
Rated 5 out of 5 by from sounds greati have an older hdtv with no audio out so i couldn't use the powered sound bars that get audio from the tv. this was the perfect solution. the sound bar looks great and once i ran the audio calibration with my receiver, the sound was great. we're using this in a smaller room and it's a perfect fit. i don't think this is something you want to use in a larger home theater set up - the low end and separation of left and right wouldn't work out right.
Date published: 2014-01-31
Rated 4 out of 5 by from Good buy for the priceI like nice things, however I am not one to spend a bunch of money. Therefore I was attracted by the price. This is one of the few decent sound-bar speakers available today that allow for direct speaker connection to a receiver amp. I mounted my unit beneath my wall-mounted flat-panel TV and it looks great. For those looking to achieve a super-flat wall-mount aesthetics, you must remember that, although it has the nice the lacquered finish which is impressive, the unit is about five inches deep from the wall. My unit sticks out a bit beneath my wall-mounted flat-panel TV. This sound bar speaker does not give the highest fidelity performance; so do not expect to crank the volume high up, and be blown way with crisp sounds. Since the left-center-right channels in the sound bar are close together, the stereo effect gets lost the farther you are from the sound bar. In my opinion, then stereo "blends" at about 5-6 feet. However, this unit the sound is solid enough for watching regular TV and the occasional movie. I am happy with this sound bar and sub. It is a good value for the price.
Date published: 2013-08-29
Rated 5 out of 5 by from Best Bang for the BuckFor the price, you can't find a better combo sounding than this.
Date published: 2012-09-06
Rated 4 out of 5 by from Great combo for the price.I was originally going to buy the speaker bar alone, as I was downsizing my HT setup from a 5.1 tower setup. I was tired of the clutter and wasn't really gaining much from a 5.1 since my application was mostly for music. But since the combo was only $18 more than the speaker bar alone, it was a no-brainer. I'm by no means an audiophile, but I do appreciate the clarity and thump that this setup gives me for such a low price. I'm sure if I replaced some of the internals with better quality components this system would sound better, but it's enough for me and I don't know enough about speaker building to modify it.
Date published: 2012-04-09
  • 2015-03-04T06:28CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_300-637, PRD, sort_mostRecent
Is the voltage universal? From 110-220volts?
Asked by: Didi
Unfortunately no, this only accepts 110v input.
Date published: 2013-03-07
What connections are actually on...this sound bar? Is there any optical connections;because I NEED two at least.
Asked by: anolesoul
This sound bar is passive which means it only has three speaker connections on the back. This system is designed to be used with a 5.1 surround sound receiver; which will have the optical inputs you need. How many depend on the model.
Date published: 2015-01-20
  • 2015-03-04T07:57CST
  • loc_en_US, sid_300-637, PRD, sort_recentQuestionsFirst
Customer projects that include: Speaker Bar and 10" Subwoofer Package
