SPDT Automotive Round Rocker Switch Black
Brand:|Model: 66-2256|Part # 060-778
Automotive top-mount press-fit round 12 VDC rocker switch. Specifications: • Current rating: 20A @ 12 VDC, 13A @ 125 VAC • Shaft diameter: 20 mm (25/32") • Contacts: 3 • Approvals: TUV, CE.
List Price$3.99
You Save73%
$1.08
Buy 10-99 $0.90
Buy 100+$0.72
Part # 060-778
Specifications: • Current rating: 20A @ 12 VDC, 13A @ 125 VAC, 6.5A @ 250V • Shaft diameter: 20 mm (25/32") • Contacts: 3 • Approvals: TUV, CE.
  • CircuitSPST
  • Contact Rating @ Voltage10A 125 VAC,20A 12 VDC
  • IlluminationNon-Illuminated
  • BrandParts Express
  • Model66-2256
  • Part Number060-778
  • UPC844632076596
  • Product CategoryRocker Switches
    (3 Reviews)
  • Weight0.01 lbs.
View similar products to the SPDT Automotive Round Rocker Switch Black
in the Rocker Switches product category.
SPDT Automotive Round Rocker Switch Black is rated 4.0 out of 5 by 3.
Rated 4 out of 5 by from good switchExactly what I expected. What you see is what you get. I'm using these for auxiliary lighting in the bed of my truck and so far so good. One note, these don't use lockrings in the back to hold in place, its just springy plastic clips that grip against the side. Works fine.
Date published: 2012-09-27
Rated 4 out of 5 by from Just the switchI know this switch is less than $2.00 but you would at least think there would be a cut out template with it. I got two different rockers that require a cutout and neither one of them came with a cut out. my performance rating is 2.5 cause i have not installed the switches yet.
Date published: 2011-01-22
Rated 4 out of 5 by from Good switch, inexpensiveNo wiring diagram is included, but the switch is two position--on and on, not on and off. Can be used in a number of ways.
Date published: 2009-05-03
  • 2016-02-12T06:33CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_060-778, PRD, sort_mostRecent
What is the diameter of the mounting hole for this part.
Asked by: Steveinny
The mounting hole diameter is about 19mm or 3/4".
Answered by: Eric Chandler
Date published: 2014-06-03
Can I use this switch on a belt-drive manual turntable?
Asked by: phillysteve
You can use this switch in any application you wish, so long as the requirements of said application do not exceed the listed electrical specifications of the switch. This is not a standard on/off switch. If that's all you need, I've linked one below for your convenience.
Answered by: RussR
Date published: 2011-04-09
  • 2016-02-12T07:15CST
  • loc_en_US, sid_060-778, PRD, sort_recentQuestionsFirst
