299-011_ALT_0
299-011_ALT_1
Sony 5" Dynamic Bass Replacement Speaker
Brand:|Part # 299-011
Well-engineered neodymium woofer for surrounds, mini monitors, or a component in compact multi-way systems.
Part # 299-011
  • Stamped steel chassis with durable metal grill
  • Blue poly cone with rubber edge
  • 4-layer copper voice coil on aluminum former
  • Neodymium magnet and extended pole piece
  • Designed for compact sealed box designs
  • Magnetically shielded
Well-engineered neodymium woofer for surrounds, mini monitors, or a component in compact multi-way systems. Magnetically shielded. Buyout, limited quantities. Specifications: *Power handling: 10 watts RMS/20 watts max *VCdia: 3/4" *Le: 1.12 mH *Impedance: 8 ohms *Re: 5.29 ohms *Frequency response: 60-4,000 Hz *Fs: 86 Hz *SPL: 85 dB 1W/1m *Vas: 0.14 cu. ft. *Qms: 5.15 *Qes: 1.19 *Qts: 0.97 *Xmax: 3 mm *Dimensions: A: 6", B: 5", C: 3-5/8" (including grill).
  • Nominal Diameter5"
  • Power Handling (RMS)10 Watts
  • Impedance8 ohms
  • Cone MaterialPaper
  • BrandFactory Buyouts
  • Part Number299-011
  • UPC844632086441
  • Product CategoryWoofers
    (10 Reviews)
  • Weight0.7 lbs.
View similar products to the Sony 5" Dynamic Bass Replacement Speaker
