Sonic Barrier Lightweight Vinyl Sound Damping Sheet 27" x 40"
Brand:|Model: VE-1|Part # 268-035
The Sonic Barrier VE-1 offers twice the damping and half the weight of asphalt based damping sheets.
OUT OF STOCK
Due In: 9/5/2016
List Price$44.99
Regular Price$33.88
You Save12%
Sale Price
$29.88
Buy 12+$26.54
Part # 268-035
  • Twice the damping and half the weight of asphalt based damping sheets
  • Easy peel and stick application
  • Makes excellent gasket material
The Sonic Barrier VE-1 was formulated for maximum damping efficiency over a broad frequency and temperature range. It is made of a mineral filled visco-elastic polymer that transforms vibrational energy into thermal energy (low level heat). It provides twice the damping of asphalt based product without the weight and odor. The VE-1 has a leather grain finish and is cosmetically pleasing, so it can be used on front speaker baffles and other applications that are visible to the eye.
The VE-1 damping sheet's flexible nature enables it to mold and conform to irregular surfaces. It can be cut easily using a standard razor knife or scissors. The pressure sensitive adhesive makes peel and stick installations easy and will adhere to most surfaces including metal, wood, and fiberglass. Excellent flame resistance, can handle continuous temperatures up to 250° F and meets UL94V-O. Thickness: .050". 27" x 40" sheet.
Home Theater: Can be used as a constrained layer between two sheets of drywall (sheetrock) to reduce wall resonance and control noise and vibration in home theater and Hi Fi listening rooms. Because VE-1 is odorless, it will not stink up your whole house!
Speaker Building: Perfect for lining the interior of your speaker cabinet. It will dramatically reduce vibration energy that would normally be stored in the walls of the cabinet. Can be used as a constrained layer between two pieces of wood. The VE-1 also makes excellent gaskets! Use between the driver and front baffle to absorb vibrations.
Automotive: You can reduce interior noise levels 3-10 dB by applying VE-1 damping sheets to the door panels, firewall, floor pan, trunk lid, or any interior sheet metal panel. Top performers in car audio competitions know that a reduction of 3 dB in the interior noise level is like doubling your effective amplifier power! Because VE-1 is lightweight (about half of asphalt sheets), it will not weigh down your automobile!
  • BrandSonic Barrier
  • ModelVE-1
  • Part Number268-035
  • UPC844632045547
  • Product CategorySound Damping
    (17 Reviews)
  • Weight3.5 lbs.
View similar products to the Sonic Barrier Lightweight Vinyl Sound Damping Sheet 27" x 40"
in the Sound Damping product category.
