Solder Spool Holder with Weighted Base
Brand:|Part # 370-345
Ideal for quickly dispensing solder, this solder reel holder features a weighted iron base and metal construction. Plastic cover on bottom protects tabletop surfaces. Holds up to 1 lb. spools. Solder not included. Net weight: 1-1/2 lbs.
List Price$14.99
You Save45%
$8.25
Buy 4-99 $7.45
Buy 100+$6.50
Part # 370-345
Dimensions: 4" x 3-1/2" x 3-1/4".
  • BrandParts Express
  • Part Number370-345
  • UPC844632013560
  • Product CategorySoldering Stands & Accessories
    (11 Reviews)
  • Weight2.0869 lbs.
View similar products to the Solder Spool Holder with Weighted Base
in the Soldering Stands & Accessories product category.
Solder Spool Holder with Weighted Base is rated 4.2727 out of 5 by 11.
Rated 5 out of 5 by from Works PerfectlyAssembly is quick and easy, and this spool holder works perfectly for all my soldering needs. Unlike some more expensive models, the full rubber base won't slip across a flat work surface, and the lift handle and solder guide are both adequate without being overcomplicated.
Date published: 2015-03-22
Rated 5 out of 5 by from Works PerfectlyNot that this job is that difficult to achieve, but the weight is nice and the feeding loop is rounded so the solder does not get caught on any square edges. Handle makes moving it around easier.
Date published: 2015-03-09
Rated 4 out of 5 by from GREAT solder holdera well made, heavy! solder holder ! -not much else to be said, woks well
Date published: 2015-02-18
Rated 5 out of 5 by from Works greatThis product is great and so is the customer service. After I received a defective spool, I was rushed out a replacement same day without question. The new one works as it should.
Date published: 2014-03-24
Rated 5 out of 5 by from Saves a lot of time in the long termIf you solder through hours you will enjoy this holder. It comes unassembled, but that is not problem at all. You can assembly it in less that five minutes. Once you have your solder roll in the holder you will gain more time in will be more productive. A must-have product.
Date published: 2014-01-21
Rated 3 out of 5 by from Works as advertisedI found this very useful, despite a small design flaw; there should be a low tension spring arm (or mechanism) across the top of the solder spool, this would stop the solder from coming off the spool, and winding around the spindle.
Date published: 2012-08-31
  • 2016-02-06T06:29CST
  • co_hasreviews, tv_0, tr_11
  • loc_en_US, sid_370-345, PRD, sort_mostRecent
