263-110_ALT_0
263-110_ALT_1
263-110_ALT_2
SMH SY50 Series 8 AWG 50A Breakaway DC Power Connector
Brand:|Model: SY6319G2|Part # 263-110
The SMH SY6319G2 battery connector is designed for use as a power quick-disconnect in automotive, RV, and marine applications, as well as other high-current DC charging circuits.
$6.95
Buy 4+$5.94
Part # 263-110
  • 8 AWG battery connector kit rated at 50A, 600 VDC
  • Impact resistant polycarbonate housing offers high physical strength and superior dielectric properties
  • Silver-plated solid copper contacts offer low resistance for superior conductivity
  • Self-cleaning contact design resists arcing by keeping conductive surfaces clean and free of corrosion
  • Contacts have flared and heat treated barrels which readily accept fine stranded wire
  • Integral stainless steel springs maintain constant pressure on the contact to insure a consistent, low-resistance connection
  • Note: Assembly includes one housing and two tips (contacts)
SMH high-current breakaway DC battery connectors are perfect for use as a quick disconnect for car audio amplifier power, RV and marine applications, and other high-current DC charging circuits. Underwriters Laboratories recognizes compatibility of SY Series battery connectors with Anderson Power Products SB® Series connectors. Requires two pieces for operation, sold individually. Dimensions: 1.88" L x 1.44" W x 0.63" H. SMH #SY6319G2.
  • UL amperage*/voltage rating: 50 amps/600 VDC
  • Operating temperature range: -20° to 105° C
  • Current rating*: 50 amps on 6 AWG wire produces 30° C rise
  • Insulation with standing test voltage (volts, dc): 2200dc
  • Maximum wire insulation diameter: 0.44"/11 mm
  • Average contact retention force: Approximately 50 lbs.
  • Average contact resistance: With 1-1/4" (32 mm) of 6 AWG wire 200 µΩ
  • Vibration resistance: Excellent
  • Mating cycles: 10,000 / For disconnect use only
  • Impact resistance: High
  • Environmental restrictions: Protected-no hydrocarbon fluids
  • Flammability Rating: UL94V-0
  • Average mating and unmating force: 15 lbs (6.75 kg)
* For largest wire or cable size
• Recognized under the component program of Underwriters Laboratories, Inc. File No. E81817
• Listed by Canadian Standards Association for use with certified equipment. File No. LR82704
  • BrandSMH
  • ModelSY6319G2
  • Part Number263-110
  • UPC844632036736
  • Product CategoryHigh-Current DC Power Connectors
    (15 Reviews)
  • Weight0.25 lbs.
View similar products to the SMH SY50 Series 8 AWG 50A Breakaway DC Power Connector
in the High-Current DC Power Connectors product category.
