263-112_ALT_0
263-112_ALT_1
263-112_ALT_2
SMH SY175 Series 1/0 AWG 175A Breakaway DC Power Connector
Brand:|Model: SY6325G1|Part # 263-112
The SMH SY6325G1 battery connector is designed for use as a power quick-disconnect in automotive, RV, and marine applications, as well as other high-current DC charging circuits.
$11.95
Buy 4+$10.92
Part # 263-112
  • 1/0 AWG battery connector kit rated at 175A, 600 VDC
  • Impact resistant polycarbonate housing offers high physical strength and superior dielectric properties
  • Silver-plated solid copper contacts offer low resistance for superior conductivity
  • Self cleaning contact design resists arcing by keeping conductive surfaces clean and free of corrosion
  • Contacts have flared and heat treated barrels which readily accept fine stranded wire
  • Integral stainless steel springs maintain constant pressure on the contact to insure a consistent, low-resistance connection
  • Note: Assembly includes one housing and two tips (contacts)
SMH high-current breakaway DC battery connectors are perfect for use as a quick disconnect for car audio amplifier power, RV and marine applications, and other high-current DC charging circuits. Underwriters Laboratories recognizes compatibility of SY Series battery connectors with Anderson Power Products SB® Series connectors. Requires two pieces for operation, sold individually. Dimensions: 3.13" L x 2.19" W x 1.0" H. SMH #SY6325G1.
  • UL amperage*/voltage rating: 175 amps/600 VDC
  • Operating temperature range: -20° to 105° C
  • Current rating*: 175 amps on 1/0 AWG wire produces 30° C rise
  • Insulation with standing test voltage (volts, dc): 2200dc
  • Maximum wire insulation diameter: 0.75"/19 mm
  • Average contact retention force: Approximately 300 lbs.
  • Average contact resistance: With 1-3/4" (45 mm) of 1/0 AWG wire 100 µΩ
  • Vibration resistance: Excellent
  • Mating cycles: 10,000 / For disconnect use only
  • Impact resistance: High
  • Environmental restrictions: Protected-no hydrocarbon fluids
  • Flammability Rating: UL94V-0
  • Average mating and unmating force: 25 lbs (11.25 kg)
* For largest wire or cable size
• Recognized under the component program of Underwriters Laboratories, Inc. File No. E81817
• Listed by Canadian Standards Association for use with certified equipment. File No. LR82704
  • BrandSMH
  • ModelSY6325G1
  • Part Number263-112
  • UPC844632003844
  • Product CategoryHigh-Current DC Power Connectors
    (3 Reviews)
  • Weight0.5 lbs.
View similar products to the SMH SY175 Series 1/0 AWG 175A Breakaway DC Power Connector
in the High-Current DC Power Connectors product category.
SMH SY175 Series 1/0 AWG 175A Breakaway DC Power Connector is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Perfect for my applicationI wanted to be able to move my deep cycle batteries between my car (for charging) and my trailer (for power while camping). No need to run high-power leads from car to trailer. These fit the bill perfectly. They provide no-worry secure connection in both environments and can't be plugged in wrong so no-worry about connection polarity, either.
Date published: 2015-05-15
Rated 5 out of 5 by from Excellent quality connectorVery sturdy construction. Heavy-Duty case and terminals. Terminals make a very tight and heavy snap-action when making connection. Easy assembly. I'm using these connectors for jumper-booster cables on my truck (I'm a mobile mechanic). Instead of using conventional jumper cables, I'm using 2AWG wire and attached this connector to one end of the wire, and heavy-duty claws to the other end. Then, the second connector is permanently mounted to the side of my truck for easy access. Thus, attach the jumper cables claws/clamps to the disabled vehicle and plug the connector to my truck. No chance of short-circuit. Item is listed correctly as one unit piece, so you'll need to order a quantity of two if you plan to use it in a similar fashion.
Date published: 2010-02-19
Rated 5 out of 5 by from ExcellentThese are the exact same construction and sturdiness of any that you may have seen in use in any industrial application. A great way to remove DC power instantly.
Date published: 2007-11-24
  • 2016-05-06T06:35CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_263-112, PRD, sort_mostRecent
Do you have a wiring diagram showing how this is connected to the power on the vehicle?
Asked by: jameson6
One lead is marked ( +) red, and the other is marked (-) black. two of these connectors interconnect to each other and generally connected directly to the battery.
Answered by: TomI
Date published: 2015-04-20
Is it possible to panel mount one of these to allow a cable connectorized with another one to properly mate? I haven't seen any panel mount versions of this connector.
Asked by: W4ZQ
I am sorry, I am not aware of any panel mount versions of this connector.
Answered by: Chrisf
Date published: 2015-04-03
what do these connectors mate with?
Asked by: younggene
These connectors mate with themselves. When you flip one 180 degrees, it will plug into another of the same type.
Date published: 2015-01-01
  • 2016-05-06T07:05CST
  • bvseo_cps, prod_bvqa, vn_cps_3.2.0
  • loc_en_US, sid_263-112, PRD, sort_recentQuestionsFirst
