262-7350_ALT_0
SKB 3I-2918-14BE Weatherproof Utility Case 29" x 18" x 14" Empty
Brand:|Model: 3I-2918-14B-E|Part # 262-7350
SKB's 29" x 18" x 14" utility case is a waterproof case with an empty interior making it the perfect solution to store and transport delicate electronics.
ORDER TODAY
Ships in 3-10 business days
List Price$379.99
You Save45%
$208.99
Part # 262-7350
  • ATA Specification 300, Category 1 Rated—the highest standard for an airline transport container
  • Built-in pull handle and wide set double wheels
  • Ultra high-strength polypropylene copolymer resin
  • UV, solvent, corrosion and fungus resistant (MIL-STD-810F)
  • Complete gasket seal makes these cases absolutely watertight (MIL-STD-C-4150J)
  • Automatic ambient pressure equalization value (MIL-STD-648C & IP67)
  • Resistant to corrosion and impact damage
Frequently Bought Together
The 3I-2918-14B-E Pro Audio Utility Case measures an impressive 29" long x 18" wide x 14" deep, is molded of ultra high-strength polypropylene copolymer resin, and features a gasketed, water and dust tight, submersible design (IP67) that is resistant to corrosion and impact damage, and an automatic ambient pressure equalization valve (MIL-STD-648C) to assist with moisture control.
This 3I Series size was the first developed specifically for the new SKB Energy Saving Hydraulic Toggle Injection Molding System at SKB's manufacturing facility in Orange, California. This injection system is one of the largest and most efficient injection molding systems in the United States.
The 3I-2918-14B-E Pro Audio Utility Case also features three protected hinges with stainless steel pins to provide lid stability, SKB's "trigger release" latch system and accepted locks built-in, an oversize double grip carrying handle to balance a heavy load, and comfortable snap-down rubber over-molded cushion grip handles on each end for a two person carry. An industrial strength injection molded pull handle and wide set double wheels offer the perfect solution to comfortable transport of pro audio equipment, cables, hardware, drum accessories or even a snare.
Specifications: • Interior length: 29" (73.66 cm) • Interior width: 18" (45.72 cm) • Interior depth: 14" (35.56 cm) • Lid depth: 2.50" (6.35 cm) • Base depth: 11.50" (29.21 cm) • Weight: 24.50 lbs. (11.11 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • BrandSKB Cases
  • Model3I-2918-14B-E
  • Part Number262-7350
  • UPC789270291812
  • Product CategoryUtility Cases & Bags
  • Weight26.6 lbs.
View similar products to the SKB 3I-2918-14BE Weatherproof Utility Case 29" x 18" x 14" Empty
in the Utility Cases & Bags product category.
