262-7346_ALT_0
262-7346_ALT_1
SKB 3I-2217-8B-E 3i Weatherproof Utility Case 22" x 17" x 8" Empty
Brand:|Model: 3I-2217-8B-E|Part # 262-7346
SKB's 22" x 17" x 8" utility case is a waterproof case with an empty interior making it the perfect solution to store and transport delicate electronics.
ORDER TODAY
Ships in 3-10 business days
List Price$279.99
You Save46%
$150.99
Part # 262-7346
  • ATA Specification 300, Category 1 Rated—the highest standard for an airline transport container
  • UV, solvent, corrosion and fungus resistant (MIL-STD-810F)
  • Complete gasket seal makes these cases absolutely watertight (MIL-STD-C-4150J)
  • Automatic ambient pressure equalization value (MIL-STD-648C & IP67)
  • Ultra high-strength polypropylene copolymer resin
  • Continuous molded-in hinge
  • Patented "trigger release" latch system
The 3I-2217-8B-E utility case with an empty interior is perfect for storing A/V equipment, microphones, mixers, cables, computers, and musician accessories. Constructed of an ultra high-strength polypropylene copolymer resin with a gasketed waterproof and airtight design to protect equipment from corrosion and impact damage. The continuous molded-in hinge, patent pending "trigger release" latch system, comfortable, snap-down rubber over-molded cushion grip handle, secure stacking, and automatic ambient pressure equalization valve (MIL-STD-648C) all contribute to its military grade design.
Specifications: • Interior length: 22" (55.88 cm) • Interior width: 17" (43.18 cm) • Interior depth: 8" (20.32 cm) • Lid depth: 2" (5.08 cm) • Base depth: 5.50" (13.97 cm) • Weight: 10.95 lbs. (4.97 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • BrandSKB Cases
  • Model3I-2217-8B-E
  • Part Number262-7346
  • UPC789270221734
  • Product CategoryUtility Cases & Bags
  • Weight12.65 lbs.
View similar products to the SKB 3I-2217-8B-E 3i Weatherproof Utility Case 22" x 17" x 8" Empty
in the Utility Cases & Bags product category.
