SKB 3I-1914-SER DJ Case for Rane Serato Mixer and Laptop
Brand:|Model: 3I-1914-SER|Part # 262-7332
SKB's 3I-1914-SER is a waterproof case with a custom designed foam interior meant to house a mixer in the lower level and any size laptop in the upper level.
Part # 262-7332
  • ATA Specification 300, Category 1 Rated—the highest standard for an airline transport container
  • Ultra high-strength polypropylene copolymer resin
  • UV, solvent, corrosion and fungus resistant (MIL-STD-810F)
  • Complete gasket seal makes these cases absolutely watertight (MIL-STD-C-4150J)
  • Automatic ambient pressure equalization value (MIL-STD-648C & IP67)
  • Continuous molded-in hinge
  • Patent pending "trigger release" latch system
The 3I-1914-SER case is based on SKB's award winning 3I Industrial strength, MIL-Spec, water tight case line. The 3I Series injection molded waterproof DJ case is constructed of ultra high-strength polypropylene copolymer resin and feature a gasketed, waterproof and airtight, submersible design (IP67) that is resistant to corrosion and impact damage. Its continuous molded-in hinge, patent pending "trigger release" latch system, comfortable, snap-down rubber over-molded cushion grip handle, secure stacking, and automatic ambient pressure equalization valve (MIL-STD-648C) all contribute to its military grade design.
The 3I-1914-SER foam interior has been custom designed to house the Rane TTM 57L mixer in the lower level with storage of any size laptop in the upper level. The laptop level includes adjustable cleats to secure any size laptop. Two additional storage compartments are included for cables and other DJ essentials. The lid has a compartment for convenient storage of multiple Serato Control Vinyl discs.
This DJ case includes a two step injection molded pull handle and two inline skate wheels along with three lock down, over-molded carry handles for convenient transportation. Combining SKB's popular 3I Injection molded case with custom form cut by our water jet machine, SKB has developed the ideal waterproof transport case for Serato Scratch Live DJ system. The 3i-1914-SER is covered by SKB’s unsurpassed no-fault Million Mile Guaranty™ (Lifetime Warranty).
Specifications: • Interior length: 19" (48.26 cm) • Interior width: 14.25" (36.20 cm) • Interior depth: 8" (20.32 cm) • Lid depth: 2" (5.08 cm) • Base depth: 6" (15.24 cm) • Weight: 14.85 lbs. (6.74 kg).
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • Construction MaterialsHardshell / ABS Case
  • BrandSKB Cases
  • Model3I-1914-SER
  • Part Number262-7332
  • UPC789270991347
  • Product CategoryMixer Racks & Cases
  • Weight12 lbs.
View similar products to the SKB 3I-1914-SER DJ Case for Rane Serato Mixer and Laptop
in the Mixer Racks & Cases product category.
