262-7325_ALT_0
262-7325_ALT_1
262-7325_ALT_2
262-7325_ALT_3
262-7325_ALT_4
SKB 3I-1813-7B-E Weatherproof Utility Case 18" x 13" x 7" Empty
Brand:|Model: 3I-1813-7B-E|Part # 262-7325
SKB's 18" x 13" x 7" utility case is a waterproof case with an empty interior to store and transport delicate electronics.
List Price$209.99
You Save47%
$110.99
Part # 262-7325
  • ATA Specification 300, Category 1 Rated—the highest standard for an airline transport container
  • Complete gasket seal makes these cases absolutely watertight (MIL-STD-C-4150J)
  • Automatic ambient pressure equalization value (MIL-STD-648C & IP67)
  • UV, solvent, corrosion and fungus resistant (MIL-STD-810F)
  • Rubber over-molded cushion grip handle
  • Continuous molded-in hinge
  • Patent pending "trigger release" latch system
Frequently Bought Together
The 3I-1813-7B-E utility case with an empty interior is perfect for storing A/V equipment, microphones, mixers, cables, computers, and musician accessories. Constructed of an ultra high-strength polypropylene copolymer resin with a gasketed waterproof and airtight design to protect equipment from corrosion and impact damage. The continuous molded-in hinge, patent pending "trigger release" latch system, comfortable, snap-down rubber over-molded cushion grip handle, secure stacking, and automatic ambient pressure equalization valve (MIL-STD-648C) all contribute to its military grade design.
Specifications: • Interior length: 18.50" (46.99 cm) • Interior width: 13" (33.02 cm) • Interior depth: 7" (17.78 cm) • Lid depth: 1.50" (3.81 cm) • Base depth: 5.50" (13.97 cm) • Weight: 6.65 lbs. (3.02 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • BrandSKB Cases
  • Model3I-1813-7B-E
  • Part Number262-7325
  • UPC789270181366
  • Product CategoryUtility Cases & Bags
    (1 Reviews)
  • Weight7.9 lbs.
View similar products to the SKB 3I-1813-7B-E Weatherproof Utility Case 18" x 13" x 7" Empty
in the Utility Cases & Bags product category.
