262-7354_ALT_0
262-7354_ALT_1
262-7354_ALT_2
SKB 3I-1711-XLX Waterproof Case for Shure SLX/ULX Wireless
Brand:|Model: 3I-1711-XLX|Part # 262-7354
SKB's 3I-1711-XLX waterproof microphone case is designed for Shure's SLX and ULX wireless systems.
ORDER TODAY
Ships in 7-10 Business Days
List Price$209.99
You Save38%
$129.99
Part # 262-7354
  • Ultra high-strength polypropylene copolymer resin
  • UV, solvent, corrosion and fungus resistant (MIL-STD-810F)
  • Complete gasket seal makes these cases absolutely watertight (MIL-STD-C-4150J)
  • Automatic ambient pressure equalization value (MIL-STD-648C & IP67)
  • Resistant to corrosion and impact damage
  • Continuous molded-in hinge
  • Patent pending "trigger release" latch system
Based on the proven 3I Series design, this case was designed to hold Shure SLX and ULX wireless systems. Interior foam can hold the receiver, quarter and half wave antenna, handheld mic, bodypack, lavalier mic, 9V and AA batteries, mic clip and power supply. Other wireless systems from other manufacturers MAY fit in this case, however, the foam is cut specifically for the Shure SLS and ULX wireless systems.
3I Series injection molded waterproof cases are constructed of ultra high-strength polypropylene copolymer resin and feature a gasketed, waterproof and airtight, submersible design (IP67) that is resistant to corrosion and impact damage. Its continuous molded-in hinge, patent pending "trigger release" latch system, comfortable, snap-down rubber over-molded cushion grip handle, secure stacking, and automatic ambient pressure equalization valve (MIL-STD-648C) all contribute to its military grade design.
Specifications: • Interior length: 17" (43.18 cm) • Interior width: 11.50" (29.21 cm) • Interior depth: 6" (15.24 cm) • Lid depth: 1.75" (4.45 cm) • Base depth: 4.25" (10.80 cm) • Weight: 7.05 lbs. (3.20 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • BrandSKB Cases
  • Model3I-1711-XLX
  • Part Number262-7354
  • UPC789270991736
  • Product CategoryMicrophone Cases & Gig Bags
  • Weight10 lbs.
View similar products to the SKB 3I-1711-XLX Waterproof Case for Shure SLX/ULX Wireless
in the Microphone Cases & Gig Bags product category.
