SKB 1SKB19-R1406 Mighty GigRig Rack System
Brand:|Model: 1SKB19-R1406|Part # 262-7203
The Mighty GigRig rack system has 14 rack space units on top and 6 rack space units on bottom.
Ships in 7-10 Business Days
List Price$1,007.39
You Save40%
Part # 262-7203
  • Accommodates deep mixers
  • Greater Vertical mixer depth
  • Accommodates the AV-14 retractable shelf
  • Indestructible injection molded side handles
  • Locking twist latches
  • Includes wheel set with locking casters
Frequently Bought Together
The newly designed Mighty GigRig by SKB now features 20 rack space units total, 14 on top and 6 units on bottom. The deeper and longer angled rack space on top allows for larger analog and digital mixers such as the Yamaha 01V96, Allen & Heath Mix Wizard, and Mackie Onyx. The deep design allows for up to 12U of vertical rack space (6U front rails standard with 6U optional rear rack rails). The Mighty GigRig includes four over-molded lift handles and four locking casters (both caster lock, roll, and swivel). The top cover of the Might GigRig can be used as a pedestal which places the mixer at proper mixing height. When packed, the cover will fit over installed XLR cable connectors (top or rear mounted).
Specifications: • Interior width: 19" (48.26 cm) • Interior height: 29.50" (74.93 cm) • Exterior depth: 32" (81.28 cm) • Exterior width: 24" (60.96 cm) • Exterior height: 26" (66.04 cm) • Rack space units total: 20 • Rack space units top: 14 • Rack space units bottom: 6 • Rack depth rail to rail: 26" (66.04 cm) • Rack depth front rail to back lid: 28.25" (71.76 cm) • Weight: 55.50 lbs. (25.17 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • Rack Spaces6U
  • BrandSKB Cases
  • Model1SKB19-R1406
  • Part Number262-7203
  • UPC789270140615
  • Product CategoryPortable Rack Cases
  • Weight70.35 lbs.
View similar products to the SKB 1SKB19-R1406 Mighty GigRig Rack System
in the Portable Rack Cases product category.
