SKB 1SKB19-R1010V 10U GigRig with Velcro Pop-Up Rack
Brand:|Model: 1SKB19-R1010V|Part # 262-7201
The 1SKB19-R1010 GigRig rack case has 10 units of angled rack space on top and 10 units of vertical rack space on bottom.
Part # 262-7201
  • Top is (10U) angled rackmount rails + 6" in rear for cables
  • (10U) rackmount on the bottom
  • 5" locking wheels
  • Improved locking covers
  • Rock solid yet very light construction
Frequently Bought Together
SKB's Roto GigRig case has set the standard for rack cases. It has 10 units of angled velcro board rack space on top for mixers and 10 units of rack space on bottom for amps. GigRig allows for safe transportation with top, front, and back lids that all lock securely together while all 4 casters lock, swivel, or roll.
Specifications: • Exterior depth: 22.25" (56.52 cm) • Exterior width: 24" (60.96 cm) • Exterior height: 27.75" (70.49 cm) • Rack space units total: 20 • Rack space units top: 10 • Rack space units bottom: 10 • Rack depth rail to rail: 17" (43.18 cm) • Rack depth front rail to back lid: 17" (43.18 cm) • Weight: 45.95lbs. (20.84 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • Rack Spaces10U
  • BrandSKB Cases
  • Model1SKB19-R1010V
  • Part Number262-7201
  • UPC789270101029
  • Product CategoryPortable Rack Cases
  • Weight62.4 lbs.
Gator GR-12L Deluxe Rack Case 12U
Part #  262-910
View similar products to the SKB 1SKB19-R1010V 10U GigRig with Velcro Pop-Up Rack
in the Portable Rack Cases product category.
