SKB 1SKB19-6U Standard 6U ATA Effects Rack Case
Brand:|Model: 1SKB19-6U|Part # 262-7195
The 1SKB19-6U standard effects rack case by SKB has 6 total rack space units.
Part # 262-7195
SKB's standard 1SKB19-6U rack case is the go to case for maximum protection. This line of 19" stackable racks has received worldwide acclaim for their durability, convenience, and easy handling. The SKB vacuum form rack made history in 1992 when it was introduced making it the professional alternative to heavy wood racks. Protect your product with the original and don't be fooled by cheap copies. Optional caster kit available.
Specifications: • Exterior depth: 21.50" (54.61 cm) • Exterior width: 22" (55.88 cm) • Exterior height: 13" (33.02 cm) • Rack space units total: 6 • Rack depth front rail to back lid: 18.25" (46.36 cm) • Rack depth front lid to back lid 20.75" (52.71 cm) • Lid depth: 2.50" (6.35 cm) • Weight: 14.70 lbs. (6.67 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • Rack Spaces6U
  • BrandSKB Cases
  • Model1SKB19-6U
  • Part Number262-7195
  • UPC789270190603
  • Product CategoryPortable Rack Cases
  • Weight16.9 lbs.
View similar products to the SKB 1SKB19-6U Standard 6U ATA Effects Rack Case
in the Portable Rack Cases product category.
