SKB 1SKB-R1717 ATA Universal Mixer Case
Brand:|Model: 1SKB-R1717|Part # 262-7227
The small size of SKB's universal mixer case is perfect for today's popular mixers from Mackie, Yamaha, Behringer, and many more.
Part # 262-7227
  • Roto Molded durability with a molded-in handle
  • Nylon cinch strap closure
  • Versatile hook and loop board with adjustable corner cleats
The 1SKB-R1717 by SKB is the perfect size for most small sized mixers that are being produced today. Able to to accommodate a variety of mixers with adjustable patented corner cleats. Features SKB’s rotational molding process, a built-in handle, molded-in valence for a tight and precise seal, and cut foam for maximum protection.
Specifications: • Interior length: 17" (43.18 cm) • Interior width: 18" (45.72 cm) • Interior depth: 4.25" (10.80 cm) • Lid depth: 2" (5.08 cm) • Weight: 10.80 lbs. (4.90 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • Construction MaterialsHardshell / ABS Case
  • BrandSKB Cases
  • Model1SKB-R1717
  • Part Number262-7227
  • UPC789270171718
  • Product CategoryMixer Racks & Cases
  • Weight12.1 lbs.
View similar products to the SKB 1SKB-R1717 ATA Universal Mixer Case
in the Mixer Racks & Cases product category.
