SKB 1SKB-R04MAC Shock Mount Rack for Mac Tower Computer
Brand:|Model: ISKB-R04MAC|Part # 262-7226
SKB's new 1SKB-R04MAC rolling shockmount tower case accommodates the powerful new Mac Pro Towers and the widely used Mac G5 Tower, providing convenient portability along with ultimate shock absorbing protection.
Part # 262-7226
  • Roto molded uni-body construction
  • Computer tower mounting bracket
  • Shock frame for upright mounting
  • Built-in wheels
  • Shock and water resistant
  • Low profile pull handle
  • Powder coated lockable latches
Frequently Bought Together
The 1SKB-R04MAC by SKB features a custom frame, which accommodates the unique shape of the Mac Pro Tower and allows for vertical mounting of the tower. Steel rack rails front and back ensure a secure mount and eight elastomeric corner shocks effectively absorb vibration and cushion the ride. The new 1SKB-R04MAC is rotationally molded for durability with Black Powder Coated Stainless Steel latches that may be locked with a customer supplied lock. A low profile injection molded, retractable pull handle and roller blade wheels combine for easy transport mobility-just tilt and go. The molded-in design contours provide extra stiffness in the lids and sides and engage for secure stacking. The rack depth is 20" from rail to rail and each lid is 2-1/4" deep. The full size doors make it easy to access the Mac Pro's multiple front and rear I/O ports. An ambient pressure relief valve and gasket sealed front and rear doors protect the Mac Pro Tower from moisture and the oversized snap-down handles on each side make for easy lifting.
Specifications: • Interior width: 19" (48.26 cm) • Interior min depth/height: 7" (17.78 cm) • Exterior depth: 28" (71.12 cm) • Exterior width: 27.75" (70.49 cm) • Exterior height: 16" (40.64 cm) • Rack space units total: 4 • Rack depth rail to rail: 20" (50.80 cm) • Rack depth front rail to back lid: 22.50" (57.15 cm) • Weight: 44.25 lbs. (20.07 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • BrandSKB Cases
  • ModelISKB-R04MAC
  • Part Number262-7226
  • UPC789270090460
  • Product CategoryUtility Cases & Bags
  • Weight47 lbs.
View similar products to the SKB 1SKB-R04MAC Shock Mount Rack for Mac Tower Computer
in the Utility Cases & Bags product category.
