SKB 1SKB-D2020 20 x 20 Bass Drum Case
Brand:|Model: 1SKB-D2020|Part # 262-7082
Keep your drum secure while transporting from gig to gig with SKB's 1SKB-D2020 20" x 20" base drum case.
Ships in 7-10 Business Days
List Price$439.99
You Save41%
Part # 262-7082
  • Stackable for convenient storage
  • Pedestal feet
  • Padded interiors for added protection
  • Heavy-duty web strap for reliable closure
  • Sturdy high tension slide release buckle
A revolutionary Roto-molded D-shaped base drum case, the 1SKB-D2020 by SKB is designed with molded in feet for upright positioning and stability. Patented Roto-X pattern for durability and reliable stacking. Sure grip handles with a 90° stop are designed for easy lifting and transporting. The entire line is truly a breakthrough in drum cases with padded interiors for added protection.
Specifications: • Interior depth: 24.25" (61.60 cm) • Diameter: 23" (58.42 cm) • Weight: 18.20 lbs. (8.26 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • Case TypeBass Drum
  • BrandSKB Cases
  • Model1SKB-D2020
  • Part Number262-7082
  • UPC789270202023
  • Product CategoryDrum, Cymbal & Percussion Cases
  • Weight23.2 lbs.
View similar products to the SKB 1SKB-D2020 20 x 20 Bass Drum Case
in the Drum, Cymbal & Percussion Cases product category.
