SKB 1SKB-D1122 Second/Double Tenor Steel Drum Case
Brand:|Model: 1SKB-D1122|Part # 262-7068
Keep your drum secure while transporting from gig to gig with SKB's 1SKB-D1122 second/double tenor drum case.
Ships in 7-10 Business Days
List Price$284.99
You Save40%
Part # 262-7068
  • High durability and strength
  • Extra ring of padding in the lid
  • Roto-molded D-shaped design
  • Roto-X pattern for added strength and reliable stacking
  • Sure grip handles with a 90° stop
  • Padded interiors for added protection
Frequently Bought Together
SKB Steel Drum Cases rotationally molded from Linear Low Density Polyethylene (LLDPE), offering high durability and strength, are designed for steel drum players who are looking for the best protection for their "pans." An extra ring of padding in the lid keeps the steel drum in place and helps prevent against the "pan" lifting up and impacting the lid during transport.
The 1SKB-D1122 Double Second/Double Tenor Steel Drum Case is a roto-molded D-shaped case designed with molded in feet for upright positioning and stability. The case includes a patented Roto-X pattern for added strength, durability and reliable stacking. Sure grip handles with a 90° stop are designed for easy lifting and transporting. With padded interiors for added protection, SKB Steel Drum Cases have revolutionized affordable steel drum protection.
Specifications: • Interior depth: 11" (27.94 cm) • Exterior width: 25.50" (64.77 cm) • Exterior depth: 12.50" (31.75 cm) • Diameter: 22.75" (57.79 cm) • Weight: 13.25 lbs. (6.01 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • Case TypeSteel Drum
  • BrandSKB Cases
  • Model1SKB-D1122
  • Part Number262-7068
  • UPC789270112216
  • Product CategoryDrum, Cymbal & Percussion Cases
  • Weight18 lbs.
View similar products to the SKB 1SKB-D1122 Second/Double Tenor Steel Drum Case
in the Drum, Cymbal & Percussion Cases product category.
