SKB 1SKB-D0922 Lead/Tenor Steel Drum Case
Brand:|Model: 1SKB-D0922|Part # 262-7064
The SKB-D0922 Lead/Tenor Steel Drum Case is a roto-molded D-shaped case with molded in feet for upright positioning and stability.
Ships in 7-10 Business Days
List Price$259.99
You Save40%
Part # 262-7064
  • High durability and strength
  • Extra ring of padding in the lid
  • Roto-molded D-shaped design
  • Roto-X pattern for added strength and reliable stacking
  • Sure grip handles with a 90° stop
  • Padded interiors for added protection
Frequently Bought Together
Designed for steel drum players who are looking for the best protection for their "pans," the SKB Steel Drum Cases are rotationally molded from Linear Low Density Polyethylene (LLDPE), offering high durability and strength. An extra ring of padding in the lid keeps the steel drum in place and helps prevent against the "pan" lifting up and impacting the lid during transport.
The cases includes a patented Roto-X pattern for added strength, durability and reliable stacking. Sure grip handles with a 90° stop are designed for easy lifting and transporting. With padded interiors for added protection, SKB Steel Drum Cases have revolutionized affordable steel drum protection.
Specifications: • Interior depth: 9" (22.86 cm) • Exterior width: 25.50" (64.77 cm) • Exterior depth: 10.25" (26.04 cm) • Diameter: 22.75" (57.79 cm) • Weight: 12.15 lbs. (5.51 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • Case TypeSteel Drum
  • BrandSKB Cases
  • Model1SKB-D0922
  • Part Number262-7064
  • UPC789270092211
  • Product CategoryDrum, Cymbal & Percussion Cases
  • Weight16 lbs.
View similar products to the SKB 1SKB-D0922 Lead/Tenor Steel Drum Case
in the Drum, Cymbal & Percussion Cases product category.
