SKB 1SKB-2416DJ ATA Single Turntable Case
Brand:|Model: 1SKB-2416DJ|Part # 262-7209
Keep your turntable secure and protected with SKB's 1SKB-2416DJ turntable case, it's perfect for the traveling DJ with a foam interior and rugged military design.
Part # 262-7209
  • Heavy duty foam interior
  • Heavy-duty spring-loaded handle
  • Rugged military designed exterior
  • Built-in bumper protection
  • Detachable lid that interlocks with base
The heavy duty foam interior protects delicate turntables. Features include: Heavy-duty spring-loaded handle, rugged military designed exterior with built-in bumper protection to absorb shock, detachable lid that interlocks with base to form a convenient "pedestal."
Specifications: • Interior length: 21.75" (55.25 cm) • Interior width: 16.75" (42.55 cm) • Interior depth: 9" (22.86 cm) • Exterior length: 24.69" (62.71 cm) • Exterior width: 19.81" (50.32 cm) • Exterior depth: 10.38" (26.35 cm) • Lid depth: 4.50" (11.43 cm) • Base depth: 4.50" (11.43 cm) • Weight: 10 lbs. (4.54 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • BrandSKB Cases
  • Model1SKB-2416DJ
  • Part Number262-7209
  • UPC789270241619
  • Product CategoryUtility Cases & Bags
  • Weight12 lbs.
View similar products to the SKB 1SKB-2416DJ ATA Single Turntable Case
in the Utility Cases & Bags product category.
