SKB 1SKB-1615 ATA Mini Mixer Case
Brand:|Model: 1SKB-1615|Part # 262-7182
SKB's 1SKB-1615 mini mixer case is the perfect case for smaller mixers measuring 18" L x 17" W x 6.75" D.
Part # 262-7182
  • Diced foam interior for a snug custom fit
  • Lockable case
  • Meets ATA 300 Cat 1 specs
Frequently Bought Together
The 1SKB-1615 mixer case's small size meets the ATA300 Cat 1 specs as an airline shipping container.  A heavy-duty polyethylene diced foam interior can be "picked and pulled" to create a snug custom fit for delicate electronics. Case is lockable for added protection.
Specifications: • Interior length: 14.50" (36.83 cm) • Interior width: 13.50" (34.29 cm) • Interior depth: 5.50" (13.97 cm) • Exterior length: 18" (45.72 cm) • Exterior width: 17" (43.18 cm) • Exterior depth: 6.75" (17.15 cm) • Weight: 7.25 lbs. (3.29 kg).
Million Mile Guaranty
SKB brand hardshell cases are fully warranted against defects in materials and craftsmanship for the life of the case to the original owner. That means, if your case breaks, SKB will either supply replacement parts, repair the case, or replace the case at no cost to you for as long as you own the case. Most locks, handles and wheels have been made field replaceable and will be supplied to you at no charge.
  • Construction MaterialsHardshell / ABS Case
  • BrandSKB Cases
  • Model1SKB-1615
  • Part Number262-7182
  • UPC789270161504
  • Product CategoryMixer Racks & Cases
  • Weight8.5 lbs.
View similar products to the SKB 1SKB-1615 ATA Mini Mixer Case
in the Mixer Racks & Cases product category.
Part # 262-7182
