Single Gang Bulk Cable Decora Insert White
Brand:|Part # 261-150
Turn any standard single gang Decora-type wall plate into a bulk cable wall plate with this insert. With a bulk cable wall plate, in-wall cable management couldn't be any easier.
List Price$10.99
You Save28%
$7.95
Buy 4+$7.29
Part # 261-150
  • Accepts HDMI and DVI cables
  • Turns Decora type wall plate into bulk cable wall plate
  • Hides cables in the wall for clean cable management
  • Easy to install
Turn any standard single gang Decora-type wall plate into a bulk cable wall plate with this insert. With a bulk cable wall plate, in-wall cable management couldn't be any easier. Simply insert the cables through the port opening, install the insert, screw on the wall plate, and you’re done! These inserts accept the wide connector on DVI cables and offers enough room to fit almost all signal cables for a typical home theater installation.
PRODUCT SPECIFICATIONS
  • SizeSingle Gang
  • FinishWhite
  • BrandParts Express
  • Part Number261-150
  • UPC741835073493
  • Product CategoryBulk Cable Wall Plates
    (5 Reviews)
  • Weight0.07 lbs.
View similar products to the Single Gang Bulk Cable Decora Insert White
in the Bulk Cable Wall Plates product category.
Single Gang Bulk Cable Decora Insert White is rated 4.0 out of 5 by 5.
Rated 4 out of 5 by from Easy to Use.The is a pretty nice cover plate. The nice little feature is the white plastic cover will slide and unclick from the metal ring that fastens to the junction box. This is helpful if you have a larger plug like a VGA plug to fit through the opening. I have it installed in the ceiling with 2 - HDMI, 1-Optical, 1-Coax, and 1-Cat5 cable. This cover seems to be holding up okay with the pressure of the cables going down.
Date published: 2011-11-21
Rated 3 out of 5 by from color?Good solution. Color looks off white to me, which sounds a little picky. But if you're an installer, then white has to white, not off white.
Date published: 2009-11-11
Rated 5 out of 5 by from Perfect!I ordered these so I could use my oil rubbed bronze switchplates as I did not like the look of the plastic ones used by my A/V guy. They look great and now match everything else. Very happy with them. They do not mount flush against the wall (perhaps 1/8") but you really can'ttell.
Date published: 2009-09-22
Rated 4 out of 5 by from Great product.Works as advertised. Fits perfectly under leviton wallplate purchased from home depot. Able to fit 4 coax cables through the opening.
Date published: 2009-09-16
Rated 4 out of 5 by from Flexible solution for In-Wall WiringThis is a great solution for running wires to/from a wall mounted flat screen TV. Because it fits the standard Decora plates, it matches nicely in a multigang plate. The opening accomodates just about any combination of wires. Putting on a faceplate locks the cover in place so that it won't pop off.
Date published: 2008-08-12
  • 2016-02-06T07:00CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_261-150, PRD, sort_mostRecent
Dose this item bubble out from the wall or bubble into the wall leaving the wall surface flat?
Asked by: Kennsa
This wall plate sticks out from the wall.
Date published: 2014-06-09
  • 2016-02-06T08:18CST
  • loc_en_US, sid_261-150, PRD, sort_recentQuestionsFirst
