242-2212_ALT_0
Shure SM58-X2U Cardioid Microphone with X2U USB Adapter
Brand:| Model: SM58-X2U
The legendary SM58 cardioid dynamic vocal microphone is now available with the X2u USB Signal Adapter, which features built-in headphone monitoring with zero latency, and easy controls to balance microphone and playback audio.
  • Dynamic mic cartridge w/a frequency response tailored with brightened mid-range and bass rolloff
  • Uniform cardioid polar pattern isolates vocal sound sources while minimizing background noise
  • Internal pneumatic shock mount minimizes handling noise
  • Legendary construction and versatility for consistent performance under rugged use and abuse
  • Plug & Play USB Connectivity allows convenience of digital recording anywhere your computer can go
  • Integrated pre-amp with Microphone Gain Control allows control of input signal strength
  • Zero Latency Monitoring for real-time playback and multi-tracking without disorientation
242-2212
Weight: 2.3 lbs.
ORDER TODAY
Ships in 7-10 Business Days
List Price$249.00
You Save20%
$199.00
Part # 242-2212
The legendary SM58 cardioid dynamic vocal microphone is now available with the X2u USB Signal Adapter, which features built-in headphone monitoring with zero latency, and easy controls to balance microphone and playback audio. Digitally record wherever your computer takes you -- just plug and play for better-than-CD quality vocal reproduction.
SM58 Microphone Specifications
• Type: Dynamic (moving coil)
• Frequency response: 50 to 15,000 Hz
• Polar pattern: Unidirectional (cardioid), rotationally symmetrical about microphone axis, uniform with frequency
• Sensitivity (at 1,000 Hz open circuit voltage): -54.5 dBV/Pa (1.85 mV)
• Impedance: Rated impedance is 150 ohms (300 ohms actual) for connection to microphone inputs rated low impedance
• Polarity: Positive pressure on diaphragm produces positive voltage on pin 2 with respect to pin 3
• Connector: Three-pin professional audio connector (male XLR type)
• Case: Dark gray, enamel-painted, die cast metal; matte-finished, silver, spherical steel mesh grille
X2U Specifications
• Plug and Play USB Connectivity allows the convenience of digital recording anywhere your computer can go (compatible with Windows 8, Windows 7, Vista, XP, 2000, and Mac OS X 10.1 or later) • Frequency response: 20 to 20,000 Hz ±1 dB
• Power requirements: USB-powered, 500 mA, maximum
• Digital noise floor (20 Hz to 20 kHz, A-weighted): Minimum MIC GAIN setting -81 dB FS; Maximum MIC GAIN setting -78 dB FS
• Sampling rate: Up to 48 kHz
• Bit depth: 16 bit
• Peak signal indicator (Tri-color): Off -30 dB FS; Green -30 to -12 dB FS; Yellow -12 to 0 dB FS; Red >0 (digital converter clipped)
• Adjustable gain range: 40 dB
• Headphone output: 3.5 mm (1/8")
  • Element TypeDynamic
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandShure
  • ModelSM58-X2U
  • Part Number242-2212
  • UPC042406167703
  • Product CategoryVocal Handheld Microphones
  • Weight2.3 lbs.
View similar products to the Shure SM58-X2U Cardioid Microphone with X2U USB Adapter
in the Vocal Handheld Microphones product category.
Customer projects that include: Shure SM58-X2U Cardioid Microphone with X2U USB Adapter
