242-2210_ALT_0
Shure SM57-X2U Cardioid Microphone with X2U USB Adapter
Brand:| Model: SM57-X2U
The legendary SM57 cardioid dynamic instrument microphone is now available with the X2u USB Signal Adapter, which features built-in headphone monitoring with zero latency, and easy controls to balance microphone and playback audio.
  • Dynamic mic cartridge w/tailored frequency response delivers clear reproduction of amplified inst.
  • Uniform cardioid polar pattern isolates the sound source while minimizing background noise
  • Internal pneumatic shock mount minimizes handling noise
  • Legendary construction and versatility for consistent performance under rugged use & abuse on stage
  • Plug & Play USB Connectivity allows convenience of digital recording anywhere your computer can go
  • Compatible with Windows Vista, XP, 2000, and Mac OS X 10.1 or later
  • Integrated pre-amp with Microphone Gain Control allows control of input signal strength
242-2210
Weight: 2.2 lbs.
ORDER TODAY
Ships in 3-10 business days
List Price$249.00
You Save20%
$199.00
Part # 242-2210
The legendary SM57 cardioid dynamic instrument microphone is now available with the X2u USB Signal Adapter, which features built-in headphone monitoring with zero latency, and easy controls to balance microphone and playback audio. Digitally record wherever and whenever your computer takes you - just plug and play for better-than-CD quality instrument reproduction.
SM57 Microphone Specifications
• Type: Dynamic
• Frequency response: 40 to 15,000 Hz
• Polar pattern: Unidirectional (cardioid), rotationally symmetrical about microphone axis, uniform with frequency
• Sensitivity (at 1,000 Hz): Open circuit voltage -56.0 dBV/Pa
• Impedance: Rated impedance is 150 ohms (310 ohms actual) for connection to microphone inputs rated low impedance
• Polarity: Positive pressure on diaphragm produces positive voltage on pin 2 with respect to pin 3
• Connector: Three-pin professional audio connector (male XLR type)
• Case: Dark gray, enamel-painted, die-cast steel with a polycarbonate grille and a stainless steel screen
X2u Specifications
• Frequency response: 20 to 20,000 Hz +/- 1 dB
• Power requirements: USB-powered, 500 mA, maximum
• Digital noise floor (20 Hz to 20 kHz, A-weighted): Minimum MIC GAIN setting -81 dB FS; Maximum MIC GAIN setting -78 dB FS
• Sampling rate: U
  • Element TypeDynamic
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandShure
  • ModelSM57-X2U
  • Part Number242-2210
  • UPC042406167697
  • Product CategoryInstrument Microphones
  • Weight2.2 lbs.
View similar products to the Shure SM57-X2U Cardioid Microphone with X2U USB Adapter
in the Instrument Microphones product category.
Customer projects that include: Shure SM57-X2U Cardioid Microphone with X2U USB Adapter
