Shure SM27-SC Side-Address Cardioid Condenser Microphone
Brand:|Model: SM27-SC|Part # 242-2208
The SM27 is a rugged and versatile large-diaphragm, side-address cardioid condenser microphone.
List Price$374.00
You Save20%
$299.00
Part # 242-2208
  • Uniform cardioid pattern for superior off axis rejection
  • Superior transient response from a low-mass large Mylar® diaphragm
  • Flat, neutral frequency response for natural reproduction on stage or in the studio
  • 3-position switchable low-frequency filter helps reduce unwanted background noise
  • Durable metal construction
  • Three separate mesh layers reduces wind and breath noise
  • 15 dB pad for performance consistency across a wider range of high SPL sources
The SM27 is a rugged and versatile large-diaphragm, side-address cardioid condenser microphone. It has low self-noise and extended frequency response that picks up vocal and instrument nuances with clarity. Durable Shure construction features three separate mesh layers that reduce wind and breath noise. Equally comfortable on stage or in the studio.
Specifications: • Type: Condenser (externally biased) • Frequency response: 20 to 20,000 Hz • Polar pattern: Cardioid • Impedance: 150 ohms (140 ohms actual) • Sensitivity (at 1 kHz, open circuit voltage): -37 dBV/Pa; • Maximum SPL (1 kHz at 1% THD): 1,000 ohm load 133 dB (147 dB, Pad on); 2,500 ohm load 138 dB (152 dB, Pad on) • S/N ratio (referenced at 94 dB SPL at 1 kHz): 84.5 dB • Dynamic range (at 1 kHz): 1,000 ohm load 123 dB; 2,500 ohm load 128 dB • Common mode rejection (20 Hz to 20 kHz): > 50 dB • Clipping level (20 Hz-20 kHz at 1% THD): 1,000 ohm load 1 dBV; 2,500 ohm load 7 dBV • Self noise (typical, equivalent SPL, A-weighted): 9.5 dB • Polarity: Positive pressure on diaphragm produces positive voltage on pin 2 with respect to pin 3 • Switch attenuator: -15 dB • Low frequency response: Flat; -6 dB/octave below 115 Hz; -18 dB/octave below 80 Hz • Connector: Three-pin professional audio (XLR), male • Power requirements: 48 Vdc phantom, 5.4 mA.
  • BrandShure
  • ModelSM27-SC
  • Part Number242-2208
  • UPC042406167635
  • Product CategoryLarge Diaphragm Condenser Microphones
  • Weight2.2 lbs.
View similar products to the Shure SM27-SC Side-Address Cardioid Condenser Microphone
in the Large Diaphragm Condenser Microphones product category.
