Shure Beta 98AMP/C Miniature Cardioid Drum Microphone
Brand:|Model: Beta 98AMP/C|Part # 242-267
The Shure Beta 98AMP/C features an integrated preamplifier and XLR connector, and comes with an A75M mount to maximize setup efficiency while minimizing stage clutter.
List Price$336.00
You Save20%
$269.00
Part # 242-267
  • Precision-engineered design for unobtrusive microphone footprint
  • Wide dynamic range for use in high SPL applications
  • A75M mount is unobtrusive, versatile, and very easy to adjust
  • Enamel-coated metal construction and stainless steel inner grill resist wear and abuse
The Beta 98AMP/C features high sound pressure level (SPL) capability, making it an excellent choice for drums and percussion instruments. An extremely uniform cardioid polar pattern provides excellent gain-before-feedback and off-axis rejection of unwanted noise. The Beta 98AMP/C's preamplifier is built into a robust metal housing, the element itself is on a flexible gooseneck, and each 98AMP/C includes an A75M mount. The A75M facilitates quick and easy mounting on virtually any drum (or stand), and allows you to place the microphone precisely where you want it. In addition, the Beta 98AMP/C ships with a zippered bag and snap-fit windscreen. Add the unequaled sound quality and rugged reliability Shure is known for world-wide, and you've got one of the finest drum mics to come along in quite some time. Requires phantom power; 48V is recommended, but the unit will operate with slightly decreased headroom and sensitivity on voltages as low as 11V.
Specifications: Cartridge: electret condenser • Polar pattern: cardioid • Frequency response: 20 Hz - 20,000 Hz • Output impedance: 150 ohms • Sensitivity (open circuit voltage @ 1 kHz, typical): -50.5 dBV/Pa (2.5mV) • Maximum SPL (1 kHz, 1% THD): 157.5 dB (2500 ohm load), 153.0 db (1000 ohm load) • Signal-to-noise ratio: 63 dB • Dynamic range (@ 1 kHz): 126.5 dB (2500 ohm load), 122.0 dB (1000 ohm load) • Clipping level (20 Hz - 20,000 Hz, 1% THD): 12.5 dBV (2500 ohm load), 7.5 dBV (1000 ohm load) • Connector: balanced XLR • Power requirements: 11 - 52 VDC phantom power, 5.5mA • Weight: 4.6 oz.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandShure
  • ModelBeta 98AMP/C
  • Part Number242-267
  • UPC042406187138
  • Product CategoryInstrument Microphones
  • Weight1.5 lbs.
View similar products to the Shure Beta 98AMP/C Miniature Cardioid Drum Microphone
in the Instrument Microphones product category.
