Selenium HM4750-SLF 2" Bi-Radial Horn 90x40 4-Bolt
Brand:|Model: HM4750-SLF
Selenium manufactures larger horns that are ideal for stage monitors, side-fill, and most P.A. applications.
List Price$150.95
You Save27%
$109.99
Part # 264-328
Selenium manufactures a variety of professional horns to complement their range of drivers. Each horn is crafted of high quality molded fiberglass, diecast aluminum, or ABS and provides different angles of dispersion to allow for maximum and optimal sound coverage to suit the particular application. Selenium horns can be used in the most demanding of touring environments. Larger format horn is ideal for stage monitors, side-fill, and most P.A. applications. Reinforced fiberglass construction.
Specifications: • Horn type: Bi-radial • Minimum frequency: 400 Hz • Nominal dispersion: 90° H x 40° V • Throat diameter: 2.0" • Mounting type: 4 hole • Dimensions: 17.52" x 11.42" x 8.27" • Selenium #HM4750-SLF.
  • Mounting Type4-Bolt
  • Entry / Throat Diameter2"
  • ConstructionFiberglass
  • BrandSelenium
  • ModelHM4750-SLF
  • Part Number264-328
  • UPC7896359508013
  • Product CategoryHorns & Waveguides
    (1 Reviews)
  • Weight6.4 lbs.
View similar products to the Selenium HM4750-SLF 2" Bi-Radial Horn 90x40 4-Bolt
in the Horns & Waveguides product category.
Selenium HM4750-SLF 2" Bi-Radial Horn 90x40 4-Bolt is rated 3.0 out of 5 by 1.
Rated 3 out of 5 by from QA or QC issuesI have employed three Selenium large format fiberglass horns-HM 3950, HM 4750 and HL 4750. All have exhibited issues with dimensional consistency from one unit to the next. Bolt hole patterns are often un-square, or if square with each other, then un-square to the flange. Bolt hole locations differ from unit-to-unit. Unit lengths can differ by 1/4 inch or more. Horn flange and throat flange are not always in parallel planes. Different units of a particular part number ARE NOT IDENTICAL!!ALSO-Bolt hole locations on the HS-50 horn bracket vary WILDLY from unit-to-unit. (Learned this the HARD way!)ALSO ALSO-Fiberglass is quite brittle. Is this the best material for a compression horn?
Date published: 2012-01-23
  • 2015-08-31T07:13CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_264-328, PRD, sort_mostRecent
