264-327_ALT_0
264-327_ALT_1
Selenium HM3950-SLF 2" Bi-Radial Horn 60x30 4-Bolt
Brand:| Model: HM3950-SLF
The Selenium HM3950-SLF 60º x 30º 2" high frequency horn delivers uncompromised high frequency output and tight directivity, making it the ideal solution for long throw applications and horizontally splayed arrays.
  • 2" throat reinforced fiberglass horn
  • Bi-radial design maintains consistent pattern control
  • 60º x 30º nominal coverage for high output/high directivity
  • Provides pattern control and acoustical loading down to 400 Hz
  • Includes HS50 support bracket
264-327
Weight: 4.75 lbs.
IN STOCK
List Price$136.08
You Save26%
$99.99
Part # 264-327
The Selenium HM3950-SLF 60º x 30º 2" high frequency horn features narrow horizontal and vertical coverage angles that focus sound energy into a tighter pattern of coverage. This characteristic, thanks to its corresponding boost in SPL, makes the HM3950 ideal for long throw applications.
The HM3950's increased directivity is also a great advantage when multiple enclosures must be deployed horizontally, thereby reducing interference issues between adjacent loudspeakers. The horn's smooth overall response and durable reinforced fiberglass construction ensure high fidelity reproduction combined with a long service life.
Specifications: • Throat diameter: 2" • Driver mounting: Four 1/4" diameter holes on a 4" diameter circle • Nominal coverage: 60º H x 30º V • Cutoff frequency: 400 Hz • Dimensions: 8.11" H x 15.35" W x 9.21" D • Cutout dimensions: 6.79" H x 13" W.
  • Mounting Type4-Bolt
  • Entry / Throat Diameter2"
  • ConstructionFiberglass
  • BrandSelenium
  • ModelHM3950-SLF
  • Part Number264-327
  • UPC7896359519279
  • Product CategoryHorns & Waveguides
  • Weight4.75 lbs.
View similar products to the Selenium HM3950-SLF 2" Bi-Radial Horn 60x30 4-Bolt
in the Horns & Waveguides product category.
How does a Bi-Radial differ from a Constant Directivity?
I'm designing a large format 3 way live sound system, but i need it to be modular depending on size needs of the venue. I'm looking at stacking one box on the subs for small to medium venues and two on top of the subs side-by-side for larger venues. Would a CD or a Bi-R work better side by side in trapezoidal boxes?
Asked by: Wrecklyss Custom Cabs
This 30 X 60 degree horn would well as a single or side by side application. Since the horn has a 2" throat, you can cross the driver over at a lower point and there will be less reflection on the walls & rear of the room [s]. I have had good success with the Eminence 2" driver. At any rate, I also suggest a crossover at 1000 Hz or higher for a 3 way system. I used that for many shows and never fried one. The other horns you are considering, are fine, but not as efficient in side by side applications. Reflections are greater--echo.
Answered by: Joe from San Francisco
Date published: 2013-11-05
Customer projects that include: Selenium HM3950-SLF 2" Bi-Radial Horn 60x30 4-Bolt
