Selenium HM11-25 1" Exponential Horn 60x60 1-3/8"-18 TPI
Brand:|Model: HM11-25|Part # 264-306
The HM11-25 exponential horn features a low cutoff frequency, compact size and is perfect for stage monitors, side fill, and P.A. applications.
OUT OF STOCK
Due In: 3/6/2016
List Price$8.79
You Save20%
$6.99
Part # 264-306
Selenium manufactures a variety of professional horns to complement their range of drivers. Each horn is crafted of high quality molded fiberglass, diecast aluminum, or ABS and provides different angles of dispersion to allow for maximum and optimal sound coverage to suit the particular application. Selenium horns can be used in the most demanding of touring environments. The Selenium HM11-25 exponential horn features a low cutoff frequency, compact size, and is perfect for stage monitors, side fill, and P.A. applications.
Specifications: • Horn type: Exponential • Minimum frequency: 1,200 Hz • Nominal dispersion: 60° H x 60° V • Throat diameter: 1.0" • Mounting type: 1-3/8"-18 TPI • Dimensions: 4.52" W x 4.52" H x 2.95" D • Cabinet cutout: 3-3/8" x 3-3/8" • Mounting gasket included.
  • Mounting Type1-3/8"-18 TPI
  • Entry / Throat Diameter1"
  • ConstructionABS
  • BrandSelenium
  • ModelHM11-25
  • Part Number264-306
  • UPC7896359519262
  • Product CategoryHorns & Waveguides
    (9 Reviews)
  • Weight0.75 lbs.
View similar products to the Selenium HM11-25 1" Exponential Horn 60x60 1-3/8"-18 TPI
in the Horns & Waveguides product category.
Selenium HM11-25 1" Exponential Horn 60x60 1-3/8"-18 TPI is rated 4.7778 out of 5 by 9.
Rated 4 out of 5 by from It WORKSBeing a cheap horn, I deliberately coupled it to a budget priced PYLE PDS221. Surprisingly, the performance is more than acceptable. Though the response is not flat, it is not jagged, making it friendly to cross.The horn can actually be used down to as low as 1,200Hz. Obviously, eq must be applied to flatten the hump from 3K-10K. For simplicity, a XO fq of 2K75 is optimum where no correction is necessary.
Date published: 2013-02-19
Rated 5 out of 5 by from great itemIf you have a small space for a horn this works great! Used it in a set of two twelve side fills and it sounded loud and full. I was really surprised by the small size, it sounded good!
Date published: 2012-04-16
Rated 5 out of 5 by from gets it done...If mounting depth is an issue you can't go wrong with these horns. Screw on a d250x and whal la. LOUD VOCALS!
Date published: 2011-10-25
Rated 5 out of 5 by from Is what it isI got this to make a blasting 12" bass cab which could double as a PA. I was putting it in place of a piezo tweeter and space was tight, otherwise a bigger horn is probably better. But it sounds pretty good with the D250-X driver! A very sturdy little item.
Date published: 2009-06-16
Rated 4 out of 5 by from Good short hornI use this horn with a D210ti in a stage monitor. The short depth is good for this application. It doesn't load down quite as far as Selenium claims, but it is low enough for the D210ti.
Date published: 2008-09-24
Rated 5 out of 5 by from great valueit beats factory lens at times the cost
Date published: 2008-06-13
  • 2016-02-08T06:27CST
  • co_hasreviews, tv_0, tr_9
  • loc_en_US, sid_264-306, PRD, sort_mostRecent
